Beginner buying an airbrush
    November 2012
Posted by Stevekir on Sunday, November 4, 2012 4:59 PM
Some advice please on buying an airbrush. I am returning to modelling plastic aeroplane kits (about 1/35 scale) after 30 years and need a suitable airbrush. Here so far what I think I need:
Dual Action, Gravity Feed, Top Cup;
Fed initially from a compressed ("air"/gas can;
Probably internal mix 'cos I am told this gives a smoother finish;
Using oil paint initially, possibly acrylic later;
If possible, no vulnerable washers etc. which deteriorate;
Spares available;
Cost? not cheap, but not what could be called "expensive".
Questions:
What make(s) (iwata seem good);
0.35mm or 0.5 mm nozzle size?
So, what makes and model numbers should I go for please? (I know that most people have personal preferences but I haven't the experience yet to have any.)
Thanks for any advice.
    June 2010
Posted by montague on Sunday, November 4, 2012 5:25 PM
Badger Anthem or Krome.
    October 2008
Posted by Don Wheeler on Sunday, November 4, 2012 10:22 PM
All major brands make good airbrushes.
Either .35 or .5mm nozzle size is OK.  .5mm is a little more forgiving.
A simple external mix airbrush like the Paasche H or Badger 350 can produce a very smooth finish.  Many car modelers use this type.  Avoid the Chinese copies.
Prices and spares availability may depend on where you live.
I would skip the canned gas and get a decent compressor with a regulator and moisture separator right off.  You will save yourself some frustration.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    June 2010
Posted by DoogsATX on Monday, November 5, 2012 2:13 AM
Iwata HP-CS Eclipse. It comes with a .35mm needle/nozzle, but you can swap in a .5mm set (I believe for the HP-BR but that may be incorrect). Since I use an HP-C+ for most of my detail work, my Eclipse usually runs the .5mm setup.
You can snag one for a great price at Hobby Lobby using their 40% off coupon, as well as the parts you might need.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    April 2004
Posted by keilau on Monday, November 5, 2012 8:18 AM
DoogsATX
I second the H P-CS Eclipse recommendation for best all round use and value in modeling. Spare is cheap and convenient to get if you have a local Hobby Lobby.
The 0.5 mm nozzle/needle/crown parts are for HP-BS and cost less than $20 at Hobby Lobby with coupons.
I agree with Don Wheeler that a good compressor is necessary from day one. If budget is an issue, you may want to look into the house brands at BearAir or TCPGlobal. Otherwise, the Sparmax at Hobby Lobby are good choices.
Posted by Don Stauffer on Monday, November 5, 2012 8:41 AM
In my opinion a compressor with regulator is more important than DA over SA, and whether gravity or suction feed.  Even the best brush will not give good results without a stable air pressure.  The can stuff will constantly change the pressure on you.  If money is a problem, consider a simpler, cheaper brush.  While I do have a DA brush, ninety percent of my airbrushing is done with a Badger 200 SA brush.
If you can stand the noise, you can get a small, cheap portable compressor for forty to fifty bucks.  Another option if you can plumb pipe through your house is compressor in garage with air piped into your workshop.
    September 2011
Posted by OMCUSNR on Monday, November 5, 2012 8:41 PM
If you can't spring  for a compressor right now, I'd recommend going to a welding supply & getting a CO2 or nitrogen tank on a rental basis.  You want an inert gas that has a low moisture content.  When you get your compressor, make sure you get a decent  regulator & moisture trap.
As for the AB, I've used a Paasche VL for over 40 years.  It's a suction feed, comes with 1/4oz, 1oz. & 3 oz cups/jars and three tip/needle combinations for shooting anything from dye, to latex house paint.  It is a bit heavy for extreme sessions, but I've found it usable for up to 3 hours.  It's a very versatile AB at about $100 for a kit .  Check out  Don Wheeler's site for some very informative reviews, and Paasche.com for their info.
Reid
Grumman Iron Works Fan.
"Don't sweat the small stuff.  And.... it's ALL small stuff, until you hear INCOMING!!!!!!"
    November 2012
Posted by Stevekir on Wednesday, November 7, 2012 1:43 PM
Thanks everyone. I have just ordered a compressor with a tank, moisture trap and regulator; a hose; and a double action gravity feed airbrush, all for £129! This will get me going and if or when I need better quality I will be able to make an informed purchase. I am also in touch with a modelling workshop every Saturday where I will learn a lot. Thanks agin.
