Iwata airbrush
    November 2012
Iwata airbrush
Posted by Dexs. on Wednesday, November 21, 2012 3:53 AM
Hi,
Wonder if you could give me some advice about the Iwata HP-CS airbrush. A friend of mine has a unused one for sale and is offering it to me for £50. As I am new to airbrushing I do not want to waste my money buying it hence my request for your advice please. Just some back ground into what it would be used for, I build 1/200 1/350 model ships. Will it be able to cover the hulls etc or is it just for fine work?
Thank you for any help.
Dexs.
    April 2004
Posted by Jon_a_its on Wednesday, November 21, 2012 5:04 AM
Get him to show you how to use it, eg demo it.
£50.00 sounds like a bargin, but make sure it is in good working order first, spares are easy enough to get in the UK, but expensive.
I find it a quality bit of kit, easiest a/b I've used, setup, use, & strip-down very easy, 5 years old & still using the original tube of needle lube.
The CS I have came with a 0.3 needle & head & will cope with some fine work, but I over-tightened the headset, knackered the needle & I replaced it with a 0.5 headset & needle (NOT interchangable) & this copes even better with Valejo & Tamiya acrylics.
I do mostly 1/35th Armour & 1/48th planes, but have done 1/76th, 1/87th &  1/60th armour with no problems... (other than talent not included Embarrassed)
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    August 2009
Posted by denstore on Wednesday, November 21, 2012 5:06 AM
I would say it is excellent for most modelling, and if you find its capacity not satisfactory, you could always complete it with a new 0.5mm nozzle and needle. At that price its a bargain even with the cost of a new nozzle and needle.
Better an airbrush in the hand, than ten in the car....Stick out tongue
