Don't forget to apply a black wash around the dials before you dry bruch the white onto the dial faces, as this, combined with the dry brushing helps 'pop' the detail out.
If you are worried about painting the dial faces, you can always apply the black wash to them, as, being thinner than normal paint it will run into the edges of the instrument bezel. Much easier.
Karl
