Alclad paint primer???
    January 2007
Posted by leardoc on Friday, December 7, 2012 1:59 PM
I'm looking for advice on which Krylon gloss black to use for an Alclad primer for by 1/48 Revell B-29. Iill be airbrushing Alclad Polished aluminum on the beast.  I've read about Krylon Gloss Black and also Krylon Fusion Gloss Black
    December 2006
Posted by Fly-n-hi on Friday, December 7, 2012 2:34 PM
Why not use the Gloss Black base from Alclad?  I use it all the time and it works great.  Its very glossy and dries in minutes.
    January 2007
Posted by leardoc on Friday, December 7, 2012 3:18 PM
Thanks Fy-n-Hi    I've heard a lot of horror stories about it not drying for days, obviously you haven't had this issue?
    October 2008
Posted by P mitch on Friday, December 7, 2012 3:43 PM
I've used a couple of the Alclad primers now. They dry pretty quick but I do let them have a day to cure. Clean your airbrush right away as I've found its a nightmare to get out even after as little as a couple of hours, and don't do it in the sink like I did once, took me an hour to clean the sink after
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
Posted by Don Stauffer on Saturday, December 8, 2012 9:52 AM
Have not used    Krylon black. I should- I use a lot of Krylon stuff.  Only concern is thickness of coat.
I have used auto body acrylic lacquer blacks of a couple of brands.  They work well- the Alclad does not seem to affect them.
I was not impressed with the Aclad black primer.  Still have most of the bottle.  Not as shiny as the other gloss blacks I use, including Testors gloss black. The Testors gloss black is the usual base I use for Alclad if I use my airbrush.  But the spray can acrylics are good for a quick undercoat on a small part.
    December 2006
Posted by Fly-n-hi on Saturday, December 8, 2012 1:38 PM
leardoc
About 2 or 3 years ago Alclad II had some quality control issue with the Gloss Black Base.  There were a few batches that went out.  These bad batches never really cured and remained tacky indefinitely.  This is why you hear all the horror stories.
This QC issue was only for a little while and they have fixed the issues.  Now, the Gloss Black Base works as advertised.
I had unknowingly purchased one of the bad bottles of the GBB and I wrote to Alclad II asking them if I was using it incorrectly.  The head guy (I don't remember his name) wrote me back explaining the quality control issue and sent me a new bottle at no charge.  It made a really good impression on me.
Here it is in action on an F-16 exhaust nozzle.  You can be the judge of whether or not you think it looks good:
Just the Gloss Black Base:
Alclad II Stainless Steel over the GBB:
    January 2007
Posted by leardoc on Sunday, December 9, 2012 10:41 PM
Thanks.....Looks real good! Since I already painted some of the parts with Krylon Fusion I'll see how it comes out. I will post pictures soon. Thanks Again
