Hello, yesterday I painted a car body with some Zero Paints blue paint. Everything went fine, when I was done I flushed a rest of paint in the cup and I rinsed my airbrush (Iwata HP CR) with Acetone, like I've always done. After flushing a few times I remove the needle for deeper cleaning, when I removed the needle I noticed that at least 1/3 of it was full of fresh blue paint ! Something unusual and certainly not normal.
So I thought that some paint went toward the back of the aribrush, meaning in the direction of the needle packing, because when I remove the back of the airbrush, the trigger, trigger holder and everything back there, there was some blue paint, which I cleaned.
I then decided to remove for the first time the needle packing, I did so. There was blue paint on the thread of the needle packing, and by using a brush I saw that there was also some left inside the airbrush where the needle packing sits.
For some reason some paint went the wrong way, and I do not know why ! I've used my airbrush for 2 months and haven't done anything unusual with it before my last session. I'd like to know what caused this. And now that everything is cleaned, I'd like to know if I should seal the needle packing thread with some beeswax and how much should I screw it in ?
Thanks a lot !!!
