Preshading White Planes
    February 2010
Posted by EBergerud on Thursday, December 13, 2012 1:55 AM
I'd like some advice on a project that's ready to paint now. At present I'm painting my first white airplane. I've never done a plane with a white belly much less most of the aircraft. (Surprised myself: lots of blues and grays but I've done say a USN three color scheme.) I was going to put on very opaque gloss black because my normal problem is covering up the preshade. I did a little experimenting and I wonder if it will work that way with white. Don't want too much paint just to cover the preshade. I was planning on using light gray primer but I suppose I could pick up some white tomorrow. Would some tone of gray or brown work better?  Very thin black? Blast away and figure it will cover? Don't want to screw this one up. Opinions from wiser heads appreciated.
Eric
A model boat is much cheaper than a real one and won't sink with you in it.
    October 2007
Posted by Milairjunkie on Thursday, December 13, 2012 3:24 AM
I would say that you are headed in the right direction with grey or light brown, black will likely look to stark. It might be worth considering the environment the aircraft was / is used in, the possible sources of dirt / contaminants & then shade accordingly.
