The paint did not come up. Though it was fairly obvious that the flat lacquer did start to come up by the change in finish. Don I did use an acrylic gloss coat, over the enamel but under the flat lacquer for the decals. Could that be it? I wouldn't have thought that the alcohol would have penetrated the lacquer to hurt the acrylic.
I ended up getting a hold of the situation with some wet sanding with a very fine grit. I let it dry up overnight and it looks pretty good. I might not do the re-shoot of flat lacquer.
John
