Model Master paint reaction with Humbrol Gloss varnish
    October 2008
Posted by P mitch on Saturday, December 15, 2012 3:52 PM
As some of  you may have seen in the Auto section I've been working on a model of my sisters new car a Mini Countryman (nothing Mini about the real thing either). So I got all the way past rubbing the Mode lMaster Gloss White with 2000 grit and thought I'd hit it with a light coat of varnish to save the finish - BIG MISTAKE. It crazed badly, pic below
So I've spent the most of the day rubbing it back down and refinishing it. Glad I spotted it before I did more than the one area
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    March 2010
Posted by Nathan T on Saturday, December 15, 2012 4:59 PM
Geez I wonder what happened? Both paints are Enamels, one isn't stronger than the other is it? If you were sanding the white I'd assume it was fully cured? I know Humbrol thinners are fairly mild. I'm not an enamel user so I can't help on the cause.
Posted by Don Stauffer on Sunday, December 16, 2012 3:06 PM
I wonder about the cure.  How long after painting did you apply the varnish?   And exactly what kind of varnish was it?  There are several types of varnish out there.  Or at least clear coats that they call varnish.
    August 2005
Posted by Phil_H on Sunday, December 16, 2012 5:51 PM
Humbrol in the tins are enamels. If I recall correctly, they made two ranges of bottled clear coats, one enamel based and the other lacquer. I haven't used it, but I believe the Gloss Cote (27307) is a lacquer.
    October 2008
Posted by P mitch on Monday, December 17, 2012 6:35 AM
I sprayed after about 3 days and a lot of polishing. The can says its "Varnish Gloss 35" but just noticed on the front it does say "for Acrylic Paint and hobby spray" so that may be the answer - it could be just for acrylic, anyway its out the door in anger already
Phil
    August 2005
Posted by Phil_H on Monday, December 17, 2012 7:34 AM
Strange - you'd think that if it was formulated for overcoating acrylics, it wouldn't be a problem putting it over enamel.
