Is water good enough for cleaning acrylic paints?
    December 2011
Posted by Chrisk-k on Tuesday, December 25, 2012 10:41 PM
Now that I have bought some high quality brushes, I want to keep them clean.  I use only acrylic paints.  Is water good enough for cleaning brushes after painting?  Or should I clean brushes with a lacquer thinner?
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    April 2006
Posted by jgeratic on Tuesday, December 25, 2012 11:07 PM
I'd suggest warm water and dish soap. Don't use hot as this can ruin the bristles and also weaken the glue that holds them in the end of brush handle.
A small drop of soap in one palm, swirl the brush gently around a few times, then while the tap is running, rinse it off.  Also don't scrub forward in the direction of the bristles are pointing, as that can ruin the brush.  When done return the bristles to their original pointed look.  Some people do this by sticking the brush in their mouth, puckering their lips and pulling out the brush - not very hygienic.   Passing it between the thumb and first two fingers is good enough.
regards,
Jack
Posted by Don Stauffer on Wednesday, December 26, 2012 9:03 AM
Lacquer thinner is about the harshest thing to use.  Natural bristle brushes are okay with lacquer thinner but it will dissolve synthetic fibers.  Alcohol (rubbing or propyl alcohol from drug store) is a safer bet for synthetic bristles.
    March 2010
Posted by Nathan T on Wednesday, December 26, 2012 9:37 AM
Use windex or simple green. Then rinse with water.
    December 2011
Posted by Chrisk-k on Wednesday, December 26, 2012 11:56 AM
Thanks, gentlemen.
