PSI Question
    March 2012
PSI Question
Posted by SoCal Dude on Friday, December 28, 2012 10:44 PM
What PSI should I run my airbrush at?
Posted by Don Stauffer on Saturday, December 29, 2012 9:42 AM
It is not real critical and depends a bit on the thinning ratio.  I run about 15 for gloss, 20 for flats.  Too high a pressure tends to make paint dry on the way to model surface, giving a rougher finish. Maybe not too objectionable on flats, bad for gloss.
Some folks say there is an atomization problem with pressures that low- I have never had a problem with atomization.
    April 2004
Posted by keilau on Saturday, December 29, 2012 9:46 AM
The recommended pressure setting should be in your airbrush owner's manual. It is different for different airbrushes and also depends on the type of paint your use.
Typical airbrush compressor gauge varies 1-3 psi between static and pulling trigger reading. But poor compressor vaires much more.
Start with 15 psi if yours is a gravity feed, or 20 psi with a syphon feed. Adjust the pressue until you get a fine misty spray from the airbrush with little or no overspray.
What airbrush do you get anyway?
