thinning Testers Model Masters Paints
    January 2011
Posted by WGreen71 on Friday, January 18, 2013 5:32 PM
I just recently had to buy some of these paints for a pinewood derby car I'm working on.  I've never work with these before so I have a couple of questions:
1.  What do I use to thin it?  I understand they are water based so I'm assuming I use water???
2.  What should I use to clean my air brush?  Again, I assume water since it's water based but not completely sure.  Thanks for any help you guys/gals can provide.
    January 2006
Posted by dirkpitt77 on Friday, January 18, 2013 5:39 PM
Are you talking about the MM enamels or do you mean the MM Acryl line?
   The Acryl line, while I'm not sure if water based, can be thinned with rubbing alcohol or distilled water. I use distilled water, myself. I use Windex with ammonia (ammonia being the key ingredient) for cleaning my airbrush.
  The enamels are not water soluble, so they need either the MM proprietary thinner and cleaner, or you can use mineral spirits or lacquer thinner. Same chemicals for cleanup.
  HTH,
  Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    November 2006
Posted by Bearcat57 on Saturday, January 19, 2013 2:30 AM
I have to assume these are MM Acryl brand based upon what you said. I use the Acryl brand thinner. I'm a believer in using the appropriate manufacturer's brand thinner for whatever medium I'm using. It may be more expensive, but a little goes a long way as long as you're only using it for thinning purposes and not also as a cleaning agent.
    August 2007
Posted by DUSTER on Saturday, January 19, 2013 3:01 PM
I'd Follow Bearcats advice, its sound.  As to cleanup for MM acryl; Windex (w ammonia) for general clean up & clearing the color or getting the air brush ready put away and then  Lacquer thinner  for a deep clean every so often
HTH
Steve
    September 2012
Posted by Tankster on Sunday, January 20, 2013 2:59 PM
Thinning depends on the nozzle size of your airbrush.  If I use my Badger 155 I can spray them right out of the bottle.  For my fine detail Iwata I'll usually add a couple drops of Future to the mix.
As for the enamels I thin them with Odorless Mineral spirits.
On The Bench: Dragon  1/35 Jagdtiger Henschel
On Deck: Dragon 1/35 Ferdinand
    January 2011
Posted by WGreen71 on Monday, January 21, 2013 10:10 AM
Thanks all, I was able to figure this out with all of your help, derby car turned out great!  Thanks.
