Tamiya Thinner goes bad?
    January 2003
Posted by CNicoll on Wednesday, January 30, 2013 9:07 PM
Has anyone had any experience with Tamiya Thinner going 'bad'?  The effect is that it seems to make the paint coagulate.  The first few times through the airbrush was strange, but then I tried putting in the cap of a different color paint and the paint really reacted differently.  Like it thickened.
On the bench:  Academy 1/72 B-17G 'Blue Hen Chick';  1/48 Tamiya Mustang III; Kitty Hawk 1/32 P-39.
Completed:  1/48 Tamiya P-51D Mustang - 'Show Bird', 1/32 Dragon P-51D  Flying Tigers 'What if'; 1/32 Tamiya P-51D Big Beautiful Doll
Group build:1/48 Tamiya Mustang III; 1/48 Tamiya P-51D Show Bird
    August 2005
Posted by Phil_H on Thursday, January 31, 2013 2:35 AM
You haven't cross-contaminated between acrylics and enamels have you?
Tamiya actually has both types, ie. acrylics and enamels. They're not available in all countries (eg, not available in the US), but in locations where they are, they're often sold side by side.
The acrylics come in round jars and the enamels in rectangular jars similar to the old Testors range. The thinners are not cross-compatible. Acrylic thinners are labelled X-20A and enamel thinners are labelled X-20  (in the 10ml size it has a clear cap, but larger sizes have a blue cap).
    October 2008
Posted by P mitch on Thursday, January 31, 2013 4:16 AM
I did have a problem a while back with Tamiya thinners, have a look at the link below
148449.aspx
In the end I tracked it down to the cleaning of the airbrush. Now after I clean it with water I run through some Vellejo airbrush cleaner and I haven't had the issue since and I'm still using the same battle of thinners too. My guess is that it was some weird reaction with something in the water!!
Hope that helps
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    January 2012
Posted by Misty on Thursday, January 31, 2013 4:36 AM
i rarely use tamiya x20a for spraying anymore, just IPA, i ALWAYS use ipa to thin it when handpainting .
    January 2003
Posted by CNicoll on Thursday, January 31, 2013 7:58 AM
Thanks for the suggestions gents... Talentless what is IPA?  alcohol?  I use acrylics exclusively, Model Master and Tamiya.  When I clean my airbrush - the last thing I run through ( after a bit of windex ) is either the MM or Tamiya thinner or cleaner.
But here's the thing that has me buggered: there seems to be a strange reaction even in the cap of the bottled paint when I use it.    I guess I should just bite the bullet and go get a couple new paints and thinner (these are nearly 3 years old by now, if not a bit older) and see how that works.  I thought I read that the Tamiya thinner is not sold in the US anymore?
    January 2012
Posted by Misty on Thursday, January 31, 2013 8:18 PM
Sorry, yes ipa is isoprpoyl alcohol.
