Paint peeling off with masking tape.
    February 2013
Posted by Wazzy3 on Sunday, February 10, 2013 1:35 PM
I am having a problem with paint lifting off with the masking tape.  I am using acrylic paint and it keeps sticking to the masking tape.  What am I doing wrong?
Wazzy3
Moderator
    September 2011
Posted by Tim Kidwell on Monday, February 11, 2013 8:54 AM
Bump for first-time poster.
Timothy Kidwell
tkidwell@firecrown.com
Editor
Scale Model Brands
Firecrown Media
    October 2010
Posted by hypertex on Monday, February 11, 2013 9:55 AM
Acrylics have that tendency. There are several things you can do to help.
1. Make sure you allow time for the paint to fully cure.
2. Use a low-tack masking tape, such as Tamiya masking tape.
3. Stick the tape to the back of your hand before you apply it to your model. This reduces the tackiness a bit.
4. Using a primer coat can also help paint adhesion.
Hope this helps.
Chris
    March 2010
Posted by Nathan T on Monday, February 11, 2013 10:20 AM
What brand acrylics are you using? Some brands are just notorious for this and should be tossed imo.
    June 2010
Posted by DoogsATX on Monday, February 11, 2013 10:21 AM
Basically what Chris said. Acrylics don't have the same "bite" as enamels or lacquers, and tend to adhere better to themselves than to underlying paint or plastic.
I would get some Tamiya tape and de-tack the stuffing out of it. The heel of your palm and underside of your wrist actually work a little better than the back of your hand for de-tacking. Don't know why but that's what I've found. I would do more than take a bit of tack off...de-tack as far as you dare.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    March 2010
Posted by ACESES5 on Monday, February 11, 2013 2:44 PM
ok what everybody else said plus do not use paper type masking tape I learned my lesson on that years ago I switched to blue painters tape Second do not mask directley over Acrylics seal with a gloss coat first let dry at least 24 hours. Paint then when you remove mask pull the tape back over it's self at a very sharp angle. Along with what everyone else said this should solve your probluem.      ACESES5         2 cents
    August 2012
Posted by AndrewW on Monday, February 11, 2013 3:55 PM
Again, what DoogATX said, detack that tape a whole lot.  I've masked over Vallejo acrylics after only a few hours with no issue.  I don't really press the tape down hard, I let it rest on top and mask.  With this method, you have to spray at 90 degrees to the surface, and I get minimal overspray if any.  The other trick is when you peel your tape, peel at a 45 degree angle and in a fluid motion.  Priming first always helps too, as hypertex mentioned.
Life is hard, it's even harder when you're stupid - John Wayne.
    January 2003
Posted by TomZ2 on Monday, February 11, 2013 4:27 PM
Consumer Reports, March 2013
Which tape is best?
[Consumer Reports] tested six versions and compared them with plain old masking taping tape.
FrogTape Delicate Surface tape, around $6 to $8, was the clear winner. It left a very sharp line, was easy to remove, and didn't damage any surface no matter how long was left on. […] [CR] painted a blue topcoat and let some surfaces dry for half an hour, others for 4 hours, 24 hours, three days, and 14 days before we pulled off the tape. […] None of the tapes damaged any surfaces or left adhesive residue, but they were slightly harder to pull off. Masking tape tore when peeled, creating more work.
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
