Newb Paint finish question
    February 2013
Posted by Admonition on Wednesday, February 27, 2013 9:36 PM
I've been reading up on all the different ways to apply a 'finish' coat to seal in and protect my model; however, if I've read 20 articles, than I've read 20 different ways to do it. Basically, I've completed my second model. I've used acrylic paints and AK's Worn Effects fluid for weathering effects. That being said, what do you all recommend I use to seal in all my painting without ruining what I've done? My main concern is applying something that'll make what I have look bad. Is applying a 'finish' paint necessary? And if I wanted to use powdered pastels to make the tank appear covered in dust, is there a different 'finish' paint I should apply to protect it all?
Thank you for the help!
    September 2012
Posted by Tankster on Friday, March 1, 2013 12:46 PM
If you apply pastels without a 'fixer' they'll blow off when you apply the final coat.  I've used MM Acryl flat & gloss to finish my models.  I use Future now for gloss coats and Krylon Flat for flat coats.  I may go back to MM Acryl Flat tho.
Acrylic finishes are what alot of people use, the only finish you need to be wary of is if you use a lacquer top coat because it can attack the paint underneath, esp acrylics if they haven't cured properly.  You should be fine with any type of acrylic varnish to seal your work in.  Thats what I would recommend.
On The Bench: Dragon  1/35 Jagdtiger Henschel
On Deck: Dragon 1/35 Ferdinand
    February 2013
Posted by Admonition on Saturday, March 2, 2013 8:07 PM
Okay, what 'fixers' do you recommend I use to make sure my pastel power/dust remains on the tank when I apply my final coat?
As far as a finishing/final coat, I don't want a gloss finish. So you recommend Model Master Acrylic Flat and Krylon Flat for that? Is it even necessary to apply a final 'sealer' coat?
    September 2012
Posted by Tankster on Sunday, March 3, 2013 12:42 AM
Its not necessary but it helps resist fingerprints in case you wanna transport it to a show or something like that.  Some paints by their nature are have a satin finish and you don't want the final result to have satin and flat finishes together you want an dead flat finish if your talking about AFVs.  Technically you should use a 'matte' finish since that's a dead flat finish.  The Krylon I have still has a little sheen to it which is why I'd say use the MM Acryl Flat b/c the Krylon isn't designed for scale models.
As far as a pigment fixer goes you I usually use Future floor polish.  You can use mineral spirits, diluted white glue or a flat varnish to hold them down as well.
