Pre-shading black models
    February 2013
Posted by Maxx02 on Thursday, February 28, 2013 6:02 AM
For my first ever build I've selected an Academy 1/72 RAAF PBY Catalina (Black Cats).   Is there any sense in preshading panels, lines etc if the overall color is matt black?   Is there a technique for defining these panels etc?
I bought Eduard PE for this kit and gave up using them.   The cockpit is so tiny and covered with perspex that you can't see in there anyway.   As for rolling the stuff for the gun barrels, forget it.   I'll try again on my next (1/48) project.
    October 2008
Posted by P mitch on Thursday, February 28, 2013 7:44 AM
Only thing I can think of is trying to change the way the black reflects the light but trying silver under the black. The problem you will have is a good coat of black will cover everything under it. May not be worth the time or hastle but if that works it could look good (and I claim the idea).
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
Posted by Don Stauffer on Thursday, February 28, 2013 8:53 AM
Personally, my feeling is that black painted subjects do not show panel lines very well compared to light colored subjects, so I don't bother with enhanced panel lines, except maybe paint chipping around edges of removable panels.
    August 2007
Posted by DUSTER on Thursday, February 28, 2013 11:58 AM
you may consider putting a "lighter" dark dark gray in the middle of the panels so that there is some small color variation and the panel lines would show by being even darkerHmm
Steve
    March 2010
Posted by Nathan T on Thursday, February 28, 2013 4:57 PM
You'll have to lighten the black with some grey or brown paint in various panels and around curves and edges. Its called post shading. Then try a light brown or gray wash.
