Buffalo canopy problem solved
    May 2012
Posted by SKEATA on Friday, March 1, 2013 9:51 PM
Worked out a way to do canopy !! one led torch , Tamiya tape, No 11 blade , one sharp HB pancil
    August 2011
Posted by Blueline on Saturday, March 2, 2013 12:06 AM
huh?
    May 2012
Posted by SKEATA on Saturday, March 2, 2013 4:29 AM
Thanks for informative and inquisitive reply
    October 2010
Posted by hypertex on Saturday, March 2, 2013 9:00 AM
Looks very nice. I can guess how the LED light, the tape, and the blade are used. But what did you use the pencil for? I'd like more info.
Chris
    May 2012
Posted by SKEATA on Sunday, March 3, 2013 6:01 AM
Hi Chris . The tape goes on the canopy ,turn the led torch ( flash light ) on its end ,light up , the light shows through and shows the out line of the frame  " the pencil" is used to mark the edge of the frame and window , cut the outer edge of pencil line NOT  ON  the line ,you have seen the result , I hope that helps
 If you look at die cast models the frame paint is above the actual  window/frame meet  That's what gave me the idea !!!!
Hope that's clear
Skeater
    August 2007
Posted by DUSTER on Monday, March 4, 2013 2:34 AM
SKEATA
Hope that's clear
Skeater
That's much clearer and a bit more user friendly.
Shall gladly give this technique a place in my "now how do I do that??" file
 Cheers
Steve
    May 2012
Posted by SKEATA on Thursday, March 7, 2013 3:57 AM
Finished !!! I don't know if I should attempt to weather her or not , to many new things at once at my second model
Tags: Finished
    May 2012
Posted by SKEATA on Thursday, March 7, 2013 4:02 AM
Tags: Finished
