Can Future be applied with a paint brush?
    December 2011
Posted by Chrisk-k on Thursday, March 7, 2013 8:00 PM
I bought Future for the 1st time today. I plan to only topically apply Future for decals.
Is it true that Future can be well applied with a paint brush?  I could airbrush it but want to avoid a hassle if possible.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    October 2008
Posted by padakr on Thursday, March 7, 2013 8:19 PM
I've always applied Future with a brush and usually just where I'm going to put the decals.
Paul
G-J
    July 2012
Posted by G-J on Thursday, March 7, 2013 8:47 PM
Yep..I believe it can.
I don't own an airbrush, so I have no choice.
On the bench:  Tamyia Mosquito Mk. VI for the '44 group build.  Yes, still.
On deck:
    February 2006
Posted by ruddratt on Thursday, March 7, 2013 10:38 PM
Yep, I apply it that way often. Works fine.
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    June 2009
Posted by kermit on Thursday, March 7, 2013 10:39 PM
Most certainly you can apply it with a brush. Future is known for it's excellent self levelling qualities. So brush marks and such are not an issue as everything will smooth out by itself.
Brushing it on will however tend to naturally lay on thicker coats as opposed to airbrushing it on. You will subsequently have a more shiny surface.
Richard
"Success is the ability to go from one failure to another with no loss of enthusiasm." - Sir Winston Churchill
    December 2011
Posted by Chrisk-k on Thursday, March 7, 2013 10:55 PM
Do you thin Future when applying it with a brush?  I think I've read somewhere that it shouldn't be thinned.  I just want to double-check.
    March 2005
Posted by TarnShip on Friday, March 8, 2013 12:31 AM
I do it both ways, brush on some models (or spots), and airbrush on others
I don't have to thin it either way, one tip about brushing it on is to not use too large a brush, or if you do use a 1/4" flat, unload it some so you don't get a flood of Future
some people also provide a means of letting any excess get off of the model, to avoid pooling,,,,,,,,but, if you put it on thin enough, you won't have that happen
also, you don't need a "very high gloss" finish to apply decals, one SG coat of Future is enough,,,,,,,,,decals are designed thin enough to go over 'some' highs and lows, so a slightly not perfect gloss is enough
if you get a "bad spot" when your Future is dry or nearly dry, don't worry,,,,,,,,,after you let it dry for a full day, you can sand a bit on the offending spot and then reapply Future to that place,,,,,it will blend in just like the "perfect" coat you laid down on the rest of your model
almost gone
    March 2010
Posted by Nathan T on Friday, March 8, 2013 8:19 AM
I've brushed it on before and put a drop or 2 of windex in the dish just to thin it a tad.
    June 2008
Posted by dr.bones on Friday, March 15, 2013 2:28 PM
when i do my minis painting i  used it to seal the colors in  and sprayed ontop a matt generic spray and up till now no problems
if you don't laugh at my english, i promise not to laugh at your spanish
    June 2008
Posted by dr.bones on Friday, March 15, 2013 2:29 PM
and yes i use a  normal brush on my minis maybe some day  i'll post 1 or 2
