Try using a paper mask (piece of paper cut to the mask shape you want) and stick it to the surface using balls or worms of either silly putty or blue tack (poster tack, that stuff that holds up a poster on a wall without putting holes in it, kind of blue or white puttyish stuff). The farther away from the surface your paper is, the softer your line will be, the closer to your surface, the sharper your line will be, both offering a very slight amount of overspray.
