Air brushing
    March 2013
Air brushing
Posted by maddogtannen69 on Sunday, March 24, 2013 9:04 AM
im new to airbrushing  i could use a little help with a single action airbrush for newbie and compressor ,whats the best to get for both ?
Posted by Don Stauffer on Monday, March 25, 2013 9:07 AM
I personally use a Badger 200 that is over 40 years old. One of the things I like is that it is almost bulletproof.  Only parts I have replaced are the teflon washers that seal the head area.  Still on my original needle. It is easy to clean, simple to reassemble after periodic complete teardown for cleaning. It is not terribly expensive as airbrushes go. Newer 200s look a bit different but internally they are much the same as my old one.  Have several friends who swear by them also.
Compressors are something else.  There are real tradeoffs there. In some ways the compressor is a harder buying decision than the airbrush.  Big question is how important is noise (or lack of it). If you don't care about noise, a small general purpose compressor from the hardware or building supply store is cheap and adequate- they start at about forty bucks and work fine for airbrushing.  Quiet compressors can be very expensive- cheaper quiet ones lack a lot of features.
    January 2006
Posted by DiscoStu on Monday, March 25, 2013 10:36 AM
I second that on the Badger 200.  It was the airbrush I started with when I was a kid and it still serves me well today.
Also have to agree on the compressor.  I'd do some homework on it.  I've been through just about every variation of compressors out there and all have their pros and cons.  I'd just recommend researching and looking at reviews of compressors.  Cheap compressors are cheap for a reason and the expensive ones may be more than you need.
"Ahh the Luftwaffe. The Washington Generals of the History Channel" -Homer Simpson
Posted by Tojo72 on Monday, March 25, 2013 10:44 AM
Badger 200 for sure
    March 2013
Posted by maddogtannen69 on Monday, March 25, 2013 11:17 AM
Its funny you guys said that I seen that the badger 200 is really good
