paint removal
    October 2012
paint removal
Posted by NamVet on Friday, April 26, 2013 12:31 PM
Any one know how to strip enamal paint from plastic model parts.
    December 2006
Posted by Jester75 on Friday, April 26, 2013 12:35 PM
I hear brake fluid works well. Never tried it myself.
Eric
    February 2013
Posted by pudnockerb17 on Wednesday, June 5, 2013 7:03 PM
I HAVE USED BRAKE FLUID TO STRIP PAINT. ITS BEST TO STRIP THE PAINT AFTER ITS HAS
BEEN APPLIED IT ,WILL COME OFF.USE A TOOTH BRUSH TO SCRUB THE MODEL  WITH  THE BRAKE FLUID. IT IS MESSY BUT IT DOES WORK.
    April 2013
Posted by KnightTemplar5150 on Friday, June 7, 2013 12:40 AM
Recently had a disaster with WalMart rattle cans, so I used Super Clean degreaser (from the automotive section of WallyWorld) to strip the enamel paints. I soaked my parts overnight and then ran water over them to remove most of the paint. Stubborn areas came off with just a quick scrub with the toothbrush. It is supposedly safe enough to dispose of down the drain, but be sure to wear gloves when handling it - it tends to do funky things to bare skin after prolonged exposure!
    October 2008
Posted by padakr on Friday, June 7, 2013 8:23 AM
Simple Green.  Non-Toxic.  No dangerous fumes.  Soak model overnight, use a soft toothbrush to get into the tight spots.  Depending on the number/thickness of coats, you may need to repeat.
Paul
    July 2010
Posted by Echo139er on Friday, June 7, 2013 9:45 AM
Yeah, what Paul said...
Simple Green works but... You need to make sure you buy the undiluted SG.  Also the longer you let it soak the better, we are talking days not hours.
