Airbrush cleaning kit should I invest in one
    October 2009
Posted by Khalee2 on Tuesday, April 30, 2013 12:49 PM
And which one?, Any recommendations.
    July 2012
Posted by JackB on Tuesday, April 30, 2013 1:21 PM
not a kit and I'm no expert but I like using...
Sparmax/Iwata-Medea Cleaning Station (good for keeping the vapor down)
Iwata-Medea Airbrush Cleaner (this one is convenient for me cause it's much cheaper at local shop than online).
REGDAB Airbrush Lubricant by Badger (good cheap lubricant).
Currently working on: Dragon 1/35 Tiger I, Initial Production s.Pz.Abt.502
    November 2008
Posted by iraqiwildman on Tuesday, April 30, 2013 1:25 PM
I also use a cleaning station I got from Hobby Lobby for about $12 with the 40% coupon. I usually just run windex then water through it after paining acrylics, or airbrush cleaner then water if shooting enamals.
Tim Wilding
Posted by Don Stauffer on Wednesday, May 1, 2013 12:13 PM
For a cleaning station I made one with a half pint jar with a plastic cover. I then cut a couple of sections of small diameter plastic pipe.  One length is glued to the top through a hole I drilled in the top (OD of pipe).  I use a 45 degree elbow between the two sections of pipe. I spray into end of the top section of pipe- spray runs down and collects in jar.  Since cleanup is mostly thinner, I have used it for a few years, never had to clean or empty jar- the thinner just evaporates between spraying sessions.
