Sometimes paint can build up around the nozzle and break loose in little blobs. You may be able to clear them by giving a good blast off to the side once in a while. If you watch many videos, you will see artists doing this. A paint brush or cotton swab with some solvent would also work. If your airbrush is a single action, and you let it sit for a short time without seating the needle, paint can leak and form a blob that gets blown off during the next spray. If your airbrush is a double action, and you don't return the needle all the way forward before letting off on the air, the same thing can happen. The sequence should always be air on, paint on, paint off, then air off.
Acrylics tend to build up on the needle. But, with enamels and lacquer thinner, I wouldn't expect to see much of that.
Don
