Paint Compatibility
    July 2013
Paint Compatibility
Posted by Pete Q on Thursday, July 11, 2013 4:21 PM
Which paints can be used with one another....Lacquer, Enamel, and Acrylic etc. General compatibility?
Posted by Don Stauffer on Friday, July 12, 2013 8:52 AM
I have never had a problem with acrylics over enamel.  I know folks who somehow use enamel over acrylics- don't know what their secret is, it has never worked well for me.
While lacquers generally are bad news over anything, Testors Glosscoat lacquers seem to work over many things.
Complicating this discussion is that now  there are things like acrylic enamels and acrylic laquers!  And, some paints do not even tell you what their chemistry is.
    July 2013
Posted by Pete Q on Friday, July 12, 2013 12:49 PM
Thanks Don for the information/comment, it is quite useful.
    October 2010
Posted by hypertex on Saturday, July 13, 2013 10:11 AM
There is a set of rules (called LEA) that some people follow, but I have found too many exceptions for the rules to be helpful. For example, some Alclad II lacquers are recommended to be applied over a gloss black enamel.
If you are layering different paints, there are a few rules that will help.
1. Always test on something other than your model. I have a couple of toy-like AFV's that I test different combinations on. When I'm done, I just strip the paint and test something else.
2. Always let the paint fully cure before you apply a different paint on top.
3. Always apply the different paint in light coats. This helps prevent the solvent from dissolving the underlying paint.
These rules are not guaranteed to work (some paints are just not compatible), but as long as you follow rule 1 and always test, you won't ruin any models you care about.
Chris
