Turning Tamiya Colors Gloss?
    November 2012
Posted by V4EVER on Thursday, August 29, 2013 1:41 PM
 Hi, I'm in need of your assistance. I need a Gloss Yellow, and I like to use Tamiya Paints. I'm going t be building Monogram A-26 Airspray.  The yellow I need is their flat Yellow, does any one know if Its possible to add Tamiya Clear to a flat to make a gloss color? Thanks :)
    April 2004
Posted by Jon_a_its on Friday, August 30, 2013 8:33 AM
Their X-marked range is Glossy, the XF-marked range is flat.
Use the Glossy range if possible, makes the decaling easier.
You could in theory, to get a semi-gloss finish, by adding gloss varnish to the flat, but best avoided if poss.
(the XF-21 is used to make Gloss.... err Flat!)
You could use Hannant's Xtracrylics (if you can find them) aircraft acrylics as these are semi to glossy, depending on how you spray them.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
Posted by Don Stauffer on Friday, August 30, 2013 9:38 AM
You can get a semi-gloss finish with a flat paint by putting it down very wet.  Also, you can make a flat finish glossy by overcoating with a clear glosscoat. I believe Tamiya makes a gloss clear, doesn't it?
Posted by ajlafleche on Saturday, August 31, 2013 9:15 AM
Just about every model paint company makes a clear gloss finish as well as teh standby Future/Klear floor polish. Lay down the flat, let it dry, coat with light clear coats until you get teh sheenyou want. MicroScale also makes a satin, a semi gloss, finish,
    August 2005
Posted by Phil_H on Saturday, August 31, 2013 10:16 AM
Is there a particular reason why you can't use Tamiya X-8 (Gloss) Lemon Yellow?
    November 2012
Posted by V4EVER on Saturday, August 31, 2013 2:43 PM
The XF Yellow is exactly the color I need with a slight tint of and orangy effect, Lemon Yellow is too bright.
    November 2012
Posted by V4EVER on Saturday, August 31, 2013 2:48 PM
I'm going to try adding Clear to the paint and see if it turns out the way I wanted, if not, then yes adding Future after is the only thing I can do,
Quando omni flunkus, mortati
Posted by ajlafleche on Saturday, August 31, 2013 3:38 PM
Do not add to the paint. Apply the gloss AFTER you've painted the nodel the base color.
    April 2004
Posted by Jon_a_its on Wednesday, September 11, 2013 7:32 AM
There are those that use Future/Klear etc., as thinners/carrier for air-brushing, inc. me.
Buuuut.... ALWAYS mix in a separate container as it is easier to bin a bodged container than spending ages cleaning out goop from the a/b.
If you do want rubbery goop, try Tamiya & cellulose/lacquer thinners....  Confused
Don't feed the CM!
