WHITE PAINT
    January 2013
WHITE PAINT
Posted by DR.FUDGE on Friday, August 30, 2013 12:05 PM
I AM CURRENTLY BUILDING THE REVEL 1/96 MODEL OF THE CONSTITUTION.  i AM HAVING TROUBLE WITH THE APLICATION OF WHITE PAINT.  i HAVE TRIED SEVERAL BRANDS AND EVEN IN USING SEVERAL COATS OF PAINT IT DOES NOT COVER PROERLY  I HAVE USED TUYAMA, MODEL SHIPWAYS , PLUS TSSTORS ANY SUGGESTIONS.
    August 2007
Posted by DUSTER on Wednesday, September 4, 2013 12:12 AM
  what?
Sorry  ,  I hate it when caps lock that stays on as you start a new text.
  1.   white is a bear to get, uh, er, white.
  2.  a light gray or white primer will help
  3.  successive light coats, of white flat allowed to set/dry, followed by a last gloss coat.
  4.  thick coats white paint, shot all at once, will not be successful
good Luck I'm sure others will have even better bits of advice.
Steve
Posted by Don Stauffer on Wednesday, September 4, 2013 9:55 AM
A light colored primer is key to a good white paint job.  There are even white primers available in spray cans at hardware stores. Krylon makes a very nice line of primers.  Have been using it for years after being led to it by another forum
    January 2012
Posted by Misty on Wednesday, September 4, 2013 12:29 PM
I had a good result using tamiya white surface primer finished with ts 26 pure white, decanted fir airbrushing. I find it hard to control gloss spraycans as it tries to go on too thick and runs. Trying to put gloss on too fast always ends in swearing for me..
G-J
    July 2012
Posted by G-J on Wednesday, September 4, 2013 9:20 PM
Though not my question, thanks for the suggestions.  I've had this problem brushing Vallejo whites of various shades.  I'm going to try a primer and see what happens.
Thanks.
On the bench:  Tamyia Mosquito Mk. VI for the '44 group build.  Yes, still.
On deck:
Posted by Don Stauffer on Thursday, September 5, 2013 9:19 AM
While gloss paint in spray cans can go on thick and tend to run, I find flats and primers pretty easy to control. I always sand out a primer a bit anyway with a fine sandpaper.
Note that with a ship model you may elect either a flat or a gloss paint.  Paints in days of Constitution were never all that glossy even when fresh, and the paint chalked rapidly.  So I always use flats on ships.  Painting is easier with flat paints- they dry faster and do not tend to run as much.  In fact, for a flat white I sometimes use the flat white primer as a finish coat- a coat for priming and then one or two coats as the final even color.
