P-40 Flying Tiger- Weathering
    September 2013
Posted by Puu72 on Wednesday, September 11, 2013 1:20 PM
i'm painting a flying tiger and experimented with colors to try and get as close to "factory" (dupont specs i think). i just completed the camouflage (tamiya acrylics air brushed) and brushed a coat of minwax polycrylic over, then realized that maybe i should have tried to get a "faded from the sun" look based on old photos.
what is the best way to attempt this now without having to go back and mask the colors again? i guess if i could go back, i would've tried a final "diluted" (maybe add white and more thinner?) coat with each of the 2 colors, but not worth the effort to go back. i'm fairly satisfied with the colors but it just looks "straight out of the factory" clean.
any tips and suggestions are much appreciated! thanks.
    April 2009
Posted by bushman32 on Sunday, December 15, 2013 8:02 PM
I know this is late, but I would go with pin filters and washes. What did you finally end up doing?
Ron Wilkinson
    September 2013
Posted by Puu72 on Monday, December 16, 2013 11:07 AM
appreciate your input. i ended up applying a light "mist" of thinned white (10:1) to try and fade out the top colors, then added a black sludge wash, soot, and silver paint chipping to add to the wear. not exactly what i was going for but satisfied with the end results.
what are "pin filters"?
how would you apply the washes for a sun faded effect?
    April 2009
Posted by bushman32 on Monday, December 16, 2013 7:07 PM
Pin filters are when you put little dots of varying colors of paint all over the model. Then with a flat brush you streak it in the direction the elements would cause weathering (e.g. downward for vertical surfaces). With the same brush, wet with the appropriate thinner, continue the streaking until just a hint of the filter is visible. On washes I use artist's oils over enamel paints. You want the foundation to be flat paint so the wash will adhere to the area. Gloss is for doing washes into recess lines, etc. For sun faded effect I use a highly diluted white. I guess this is a filter and not a wash, sorry about that.
Ron Wilkinson
    April 2009
Posted by bushman32 on Monday, December 16, 2013 7:09 PM
Actually, I guess a "pin filter" is actually called a pin wash!
Ron Wilkinson
    September 2013
Posted by Puu72 on Monday, December 16, 2013 9:07 PM
great tips on washes, thanks! i'll try the "pin filter (wash)" on a Mk.I Spitfire i'm currently finishing.
question on the sun faded effect: how do you apply the highly diluted white and at what dilution? do you brush it on or by AB?
    June 2012
Posted by Compressorman on Monday, December 23, 2013 9:45 AM
Puu72
I just make a diluted and lightened (I add white or tan) of my original color and spray over it. I do not think that you will need to mask over again as long as you are careful. Many people do their camouflage jobs entirely by 'eye' with no masks at all.
I have never tried it but I would like to try to fade my paint job with pastels one day. I would imagine that some people here have tried this and I would like to hear of their results.
Chris
    September 2013
Posted by Puu72 on Monday, December 23, 2013 8:41 PM
thanks for the input chris ,that probably would have been a better way to go in lieu of what i did which was applying a very diluted white to the overall. i'll try and fool with it on scrap later and compare.
yeah, eye-balling would save a lot of labor but not there yet.
Posted by Don Stauffer on Tuesday, December 24, 2013 8:54 AM
I use an airbrush, and mask only the canopy.  Over camouflage I lay on a very thin coat of a very light, flat gray.  I come at model from top, and get top of fuselage, top of wings and horizontal tail surfaces.  Oh, I also mask of the spinner on planes like the P-40 that have prominent spinners (every time the plane is shut down it may rotate to a new portion of the spinner being the top.)
    September 2013
Posted by Puu72 on Tuesday, December 24, 2013 12:59 PM
thanks, i'll add flat gray in fading trials. being out of modeling since the early 70's, didn't realize how "intense" scale modeling has become. lots to catch up on! tip of the iceberg with this flying tiger. research, history, color schemes, techniques, tools, resources...amazing stuff! great forum.
