using primers
    December 2011
using primers
Posted by Lavarre on Thursday, October 3, 2013 4:48 PM
I am a very avid builder of plastic model airplanes, and I,m proud of the work i've done as a pastime.  I have subscription to fine scale modeller and also model airplane international(out of the UK).  i usually work with enamels and occasionlly to acrylics and alcad.  When i use enamals i don't use primers.  I know almost all experts in the modeling field  mention "Primers". I'm really curious as to what kinds of primer I should use when finishing the plane with enamels. Are there special primers out there or is a primer coat just a lighter colored enamel paint ?
Tags: enamel
    August 2012
Posted by AndrewW on Friday, October 4, 2013 6:40 AM
Primers are a different paint than the top coat.  Simply, they're meant to provide a sawtooth or bite for later layers.  Generally, they're a neutral color (grey, rust, white) and when they dry they're very rough (very fine grade sandpaper texture).  This allows other layers to stick to them well without lifting.  Primers are definitely a must, in my opinion, for acrylics as acrylics are not hot and do not bond to the plastic at all, but rather sit on top.  Enamels are hot, so they tend to bite into the plastic a little, making them harder to lift away.
Humbrol, Testors, Vallejo all make primers of varying types.  You'd have to do a little research into what plays well with enamels.
Hope that helps
Life is hard, it's even harder when you're stupid - John Wayne.
Posted by Don Stauffer on Friday, October 4, 2013 9:42 AM
There are different color primers, all the way from white to black, with greys, reds and even some yellows.  Primers have two main uses, acting to improve paint adhesion and to fill small cracks, nicks and scratches (some are very thick in order to do this better).  Also a secondary use is when the kit is multi-media (styrene and resin), or when the kit has different colors, the different colors on an assembly can prevent the eye from really evaluating the smoothness near the seam between the pieces.  A uniform color from the primer gives you a better idea of what the seam really looks like.
I personally use Krylon primer, which comes in white, black, or a medium dark gray. It is very full bodied, which makes some modelers afraid it will obsure fine detail. It is a bit rough, so always needs to be sanded with fine sandpaper before the first color coat.  Because of the full body, it sometimes fills seams by itself eliminating the need for putty on well-fit seams.
