AIrbrush problems
    December 2009
AIrbrush problems
Posted by ww2psycho on Saturday, November 2, 2013 4:46 PM
I'm starting to airbrush another tank and it seems every time I use it that it stops spraying paint even though I do not move the handle/botton that controls the airflow and paint. I have a double action brush. So when I'm in the middle of painting it will just stop. To get it started again I usually have to pull the handle all the way back to unclog it. I've been trying to thin the paint more or turning the air pressure down since it seems to be pretty high (about 20psi). Can anyone help me solve this? I cant have this happening when painting the camo.
Posted by Bish on Saturday, November 2, 2013 4:49 PM
Don't want to sound like I am trying to teach you to suck egg's, but are you sure its cleaned properly. Other than that, are you sure there are not any lumps in the paint.
    December 2009
Posted by ww2psycho on Saturday, November 2, 2013 5:08 PM
I clean every part of it every time I use it, paint shouldn't be, I have one of those electric mixers and stir it for a good minute or two before using. I may have found it, I think the jar is too low on paint so its sucking air up at times instead of paint since I seem to angle it when painting.
Posted by Bish on Saturday, November 2, 2013 5:24 PM
Yep, that will do it. But always handy to eliminate the obvious ones first.
    December 2009
Posted by ww2psycho on Saturday, November 2, 2013 5:30 PM
Its still doing it, and the compressor is getting a lot of condensation build up even though there is a filter for it, going to clean it and let what I have done dry before starting again.
    March 2005
Posted by TarnShip on Saturday, November 2, 2013 6:32 PM
if you are using Acrylic paint, you might want to look at getting some Slo-dri and/or Flow Aid
Acrylic "tip dries" which is a form of clogging, if it is sprayed too thick or at too high an air pressure
using the Flow Aid lets the airbrush be set at a lower pressure,,,,and the Slo dri lets us spray a thinner color coat,,,,,,,,both of those keep the cotton swab full of airbrush cleaner away from the tip a bit longer during use (we can't fully eliminate it)
almost gone
    May 2012
Posted by pilotjohn on Saturday, November 2, 2013 7:42 PM
I agree with what the other guys have said.  You mentioned turning "down" the pressure.  That is going to make it harder to "push" the paint through of there are any issues.  I would test by turning the pressure to 25 psi and see if it sprays with the needle all the way back.  If it does, then slowly lower the pressure and then the needle travel until you see where the issue is.  That will tell you what is wrong.
If you have a real clog, I would think that it would not spray at any pressure (within reason).  Tip dry is a big issue with acryl paints.  I use a 50/50 mix of paint and a Golde airbrush medium  as it won't dilute the color like thinning can and it has a retarder in it for tip dry.  I still keep a cotton swab soaked in water and routinely clean the tip.  Check the tip with a magnifier to see if it has dried paint on it.
John
    December 2009
Posted by ww2psycho on Saturday, November 2, 2013 8:10 PM
I'm using Model Master enamels thinned with Mineral Spirits.
    May 2012
Posted by pilotjohn on Saturday, November 2, 2013 8:27 PM
I would clean it out thoroughly and then see if it will spray just water.  I doubt it is the airbrush.  They are pretty simple mechanisms.  If it is a siphon feed, make sure you have the tube well into the liquid.
Good luck.
John
    August 2005
Posted by Phil_H on Saturday, November 2, 2013 11:16 PM
pilotjohn
Also, make sure that the breather hole in the paint jar cap isn't blocked. Wink
    December 2011
Posted by Chrisk-k on Sunday, November 3, 2013 1:25 AM
A siphon-fed AB needs high psi to function properly, especially when the jar is less than half full (20 or higher).  You may want to use a cup rather than a jar so that you can use your AB sort of like a gravity-fed AB.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    December 2009
Posted by ww2psycho on Sunday, November 3, 2013 7:55 AM
Thanks guys! I'll try the cup today, the jar has always given me trouble, I figured it was my lack of experience with it.
    December 2009
Posted by ww2psycho on Sunday, November 3, 2013 11:26 AM
I changed to a bigger nozzle and it seemed to help a  bit, and I remixed the paint/thinner. It helped somewhat but I will still try the cup today.
Posted by Don Stauffer on Monday, November 4, 2013 9:42 AM
You didn't say what type of airbrush you are using, but many Badger models have a teflon washer that seals the spray head area.  A bad washer that needs to be replaced will cause the intermittant interruption of spraying.
I use a siphon feed Badger and use 15 psi as my pressure.  Never have problems picking up paint when brush is clean, and the washer is fresh.
    December 2009
Posted by ww2psycho on Monday, November 4, 2013 12:12 PM
I have a Paasche VL0408, I used the cup a few times since having the problem and it seems better. I'll do some testing before painting the camo on the tank.
