if your cap is on the bottle tight enough that paint won't seep out the threads when standing upside down,,,,,,,then they are tight enough to keep the air out if you store them upright
the seal on a model paint bottle is not the threads, anyway,,,,it is either the outside edge of the bottle up against the bottom of the flat cap liner,,,,,or the inside of the bottle into the sealing lip of a bottle (or cone liner on those types of caps
the Vallejo type of caps have the tip with the opening going up into a sealing area in the screw on cap
you get much more life extension just by keeping the threads in the cap and bottle clean,,,and wiping out the cap before you tighten it down
