strange problem with SnJ Aluminum
Posted by Texgunner on Monday, February 23, 2004 7:17 PM
Has anyone experienced a problem like this with SnJ aluminum? I have a 1 oz. bottle that's a bit less than half-full that has "separated" into 3 distinct layers. On top there is a clear solvent, then a milky white semi-solid layer and at the bottom there is the silver pigment. The silver pigment doesn't look like it originally did however; it is very granulated. Overall, it looks really weird. Nothing at all like it did when new. It was used only once or twice and then put away. When I checked it again, months later it looks as it does now. It is completely unusable. Any ideas out there? thanks all, Gary .
"All you mugs need to get busy building, and post pics!"
Posted by Bones-coa on Tuesday, February 24, 2004 10:45 AM
I bought a bottle from a hobby shop once that apparently had been on the shelf awhile. I started using it and notice it wasn't really covering. Looking at it and compared to another bottle, I noticed that the liquid was dark and grainy looking compared to the other. It's like it wouldn't mix. I'm not sure if that's your problem but I can say that the stuff does have a shelf life.
Dana F On the bench: Tamiya DO335B-2 with LOTS of Aires stuff (On Hold) Trumpeter A-10 with LOTS and LOTS of aftermarket goodies! (On Hold) Tamiya 240ZG (In work)
Posted by Anonymous on Tuesday, February 24, 2004 3:09 PM
i read some where that if you put the unused SNJ in a smaller container it will keep
