Tank it!
Tank with regulator, even if you use a MAC valve, as a tank allows the air to settle out water vapour, & also doesn't have to run constantly, & the regulator/moisture trap, err traps moisture
I have a 'fridge engined one with a U shaped tank handle, + regulator/moisture trap, & treated myself to a 3m/9ft braided hose with an on-airbrush moisture trap, virtually silent, which makes it a pleasure to use.
I upgraded from a diaphram-type piston engined pressor, that made more noise than a dirt-bike & would dance off the table!
Teeth-grindingly Dementoring!
