Compressor Problems
    June 2013
Compressor Problems
Posted by RobGroot4 on Friday, January 17, 2014 4:16 PM
I was hoping someone might have some mechanical knowledge.  I have a Badger airstorm compressor that is "having problems."
I've had the counterweight that connects the motor output shaft to the piston come unscrewed a couple times now.   I can screw it back in, but I can only get it hand tight due to the compressor housing.
I've also noticed that the compressor will sometimes not kick back on when the pressure gets low.  Normally, if I have it set for a 20 psi working pressure, it will build pressure to about  25 psi or so, I'll trigger the airbrush and it will drop to about 20 psi and start running.  I've noticed lately that when I trigger it doesn't always kick on again and will drop to around 5 psi before coming on.  It gets back to pressure really quickly, but it makes painting adventurous to say the least.
I am wondering if perhaps the pressure switch or maybe the gasket above the piston might need replacing.  I'm also wondering if there is something I can put on the motor output shaft (like plumber's tape or pipe dope) that will help the counterweight keep from unscrewing.  Any help or suggestions are appreciated.  Thank you!
Groot
Tags: compressor
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    February 2015
Posted by Bick on Friday, January 17, 2014 5:26 PM
Sounds like the pressure switch. If so, can't help much. Re the counter weight you could use permanent "LockTite" (or even non-permanent) on the threads. Put some on, screw counter weight on, let sit for an hour then try it. Be aware that if you do this, unscrewing the counterweight again will require a lot of heat.
RobGroot4
<SNIP>
Groot
    June 2013
Posted by RobGroot4 on Friday, January 17, 2014 6:33 PM
Thanks, I was afraid of that.  It's listed on the parts schematic, but there's no number for several of the parts and it's one of them.  I'll probably have to get the manufacturer's tech support on the phone to order a pressure switch, to make sure I know where to put it when I get it!  I will definitely look into the lock tite.  The two parts shouldn't come apart, ever, so I'm not worried about needing to separate them.
Thank you!
Groot
