Using salt for chipped paint
    February 2013
Posted by Recon89 on Tuesday, February 18, 2014 3:11 PM
The first time I used the salt trick for chipped paint, it came out perfect.  Put the salt on over a base coat, painted over it, brushed the salt off, and perfect chipped paint.  This time I did what I thought was the same procedure, and when I painted over the salt, it left big blotches around the salt.  Sprayed over it again, but can't get rid of the blotches.  Any idea what I did wrong?  Did I mix the salt with too much water?  I wasn't using very much salt.
Thanks.
    August 2007
Posted by DUSTER on Tuesday, February 18, 2014 4:53 PM
I'm not an expert but sounds like the salt dissolved and that caused your blotches.
Some use this part of the technique  ( salt dissolving ) as part of their weathering. Can only think for chips only just a "damp enough to hold salt " method would be your best bet.
Steve
    March 2010
Posted by Nathan T on Wednesday, February 19, 2014 8:14 AM
Does gloss coating the model make them go away?
    February 2013
Posted by Recon89 on Thursday, February 20, 2014 7:32 AM
I didn't try anything other than another coat of paint.  It's in the "What do I do with this?" bin in the back room.  Have to dig it out sometime and give it a try.
    March 2010
Posted by Nathan T on Thursday, February 20, 2014 8:48 AM
Sometimes just gloss coating the model will cause these stains to completely disappear. Try it out.
