Is a 1/3 oz paint cup large enough?
    December 2011
Posted by Chrisk-k on Tuesday, March 25, 2014 2:32 PM
I personally find it much easier to use and much easier to clean gravity-feed AB's (I have an Iwata HP-CS & HP-B+) than siphon-fed AB (I have an Iwata SAR).  As I become better at airbrushing, I really dislike dealing with paint bottles.
The only reason why I might keep using my SAR is its ability to hold a large volume of paint.  However, since I build only 1/35 armor and 1/48 aircraft, I'm not sure if I ever need more than 1/3 oz (9 ml) of paint for a single session (The HP-CS has a 1/3 oz cup).  What do you think?
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    February 2015
Posted by Bick on Tuesday, March 25, 2014 5:00 PM
I switched from siphon to gravity feed a number of years ago and don't remember the last time I used my Paasche Model H or Binks 'Wren' or Badger 200.I've kept all three of the above for sentimental reasons but sold other siphon feed I had acquired over the years. I, too, find cleaning bottles a hassle. And, I often use the smallest cup (1/2 ml?) on my Evolution. I don't find the 1/3oz cup a problem at all for even larger areas..
Posted by Wingman_kz on Tuesday, March 25, 2014 8:26 PM
I have a Badger 360 that's seldom used anymore but it isn't eating anything and I already have a drawer full of bottles and caps. It comes in handy at times like, painting a car body or priming. I keep a tub of Castrol SuperClean under the sink and when I use the 360 I just drop the bottles and caps in that tub, let them soak a day or two and then rinse. True, a little more work than cleaning a cup but no big deal. Tony
    April 2009
Posted by Cadet Chuck on Tuesday, March 25, 2014 10:52 PM
Yes, I  find the small gravity feed cups plenty big for most work… I never use the siphon feed jars anymore.  If I need that much paint, I'll use a spay can.
    February 2011
Posted by Raualduke on Wednesday, March 26, 2014 7:46 AM
Only reason I've shied away from gravity feeds is the fear of spilling.I'm pretty clumsy
    March 2010
Posted by Nathan T on Wednesday, March 26, 2014 8:32 AM
I have an HP-CS too, and 1/3 oz cup is more than enough, even for my largest 1/48 models. If you remember to cap it, its almost impossible to spill.
Posted by Don Stauffer on Wednesday, March 26, 2014 9:37 AM
I hate cleaning the bottles, but I still use a siphon feed brush.  Biggest reason is that if I mix paint, and need to use that color later, I need to put it in a bottle anyway, in order to be sure the color matches (not confident of abililty to mix the same exact color on seperate occasions.  The other reason is I find myself turning the brush on its side periodically.  With a siphon feed brush the paint only dribbles out very slowly and I can see that happening, and straighten  brush out long before all the paint has spilled out :-)
    December 2011
Posted by Chrisk-k on Wednesday, March 26, 2014 11:58 AM
My next build will be a 1/35 Tamiya Elefant, which is big.  If I manage to apply a base coat using less than 1/3 oz of paint, it means that I won't need my siphon-fed AB.
    March 2010
Posted by Nathan T on Wednesday, March 26, 2014 8:00 PM
That will of course depend on the paint you use and how much it needs to be thinned.
Posted by Don Stauffer on Thursday, March 27, 2014 9:47 AM
One thing that can cut down on the amount of paint needed is to use a good primer that is close to color of paint you will use. Even just matching gray value helps a lot.
    March 2005
Posted by TarnShip on Thursday, March 27, 2014 7:17 PM
if you paint like Drewe does, then 1/3 oz is a Huge volume of paint
www.youtube.com/watch
ever since he posted this last week or so, I have adjusted my target for using my airbrush,,,,,,,I thought I had the volume and pressures down low, but, not like this
Rex
almost gone
    August 2005
Posted by Phil_H on Friday, March 28, 2014 12:04 AM
TarnShip
Rex
I've always said, using denatured alcohol or lacquer thinner, you can thin Tamiya acrylics way down and still get good coverage because the paint (typically the flats) has a fairly heavy pigment load. The video more or less proves it. One drop of paint plus 3-4 drops of thinner will typically cover about 3-4 square inches, depending on your technique.
Posted by Don Stauffer on Friday, March 28, 2014 9:28 AM
I am working on a 1:350 scale heavy cruiser and it looks like it will need another jar of the dominant color, but this is unusual. Usually a bottle does a model easily.
