Do you backflush your airbrush?
Posted by MikeV on Friday, February 27, 2004 10:35 AM
I have heard of a lot of people doing this, I have even done it before, and I see it recommended in even some airbrush literature, but it is not a good idea.
I emailed Dave at Coast Airbrush about it the other day because someone on this forum or another mentioned that Dave had told them the same thing.
I mention Dave in this post because he is one of the most knowledgable people in the country on airbrushes and compressors so I value his advice.
He is basically the guy who got me started in airbrushing and helped me out a lot in the early years.
Here is what he told me concerning cleaning airbrushes in general and whether using pipe cleaners is a bad idea:
QUOTE:
The back flushing is mostly for t shirt type paints.
Its usually for a quick fix.
I dont like it because it puts paint into areas that dont normally see paint.
Then the only way they get clean is to take the brush apart and clean it.
Pipe cleaners come apart and when mixed with paint create a big mess inside.
I do like all the nylon type cleaning brushes . They work great for tuff dry paint probs. Its pretty simple, the paint chambers are the only thing that should have paint in them so clean those areas and your fine.
Some people have gravity feed brushes and when they pull the needle back or out with cleaner or paint in the cup it leaks into the mecanical parts of the gun.
There shouldn't be any paint back there. Back flushing sometimes forces paint past the needle bearings.
Soaking parts is cool, but when you soak the whole gun, paint gets into the small air chambers and makes everything gummy.
I hope this helps
This is good advice.
Posted by jridge on Friday, February 27, 2004 2:42 PM
I can not tell a lie. I cut down the cherry tree ---- oh, sorry, wrong story. But, I did mention back flushing in another post.
The Omni 6000 literature, what there was of it, recommended back flushing as part of the AB cleaning routine. But a subsequent call to Coast Air Brush, I didn't talk to Dave, put the cabash on that procedure --- exactly for the reasons you state.
Jim The fate of the Chambermaid http://30thbg.1hwy.com/38thBS.html
Posted by Anonymous on Friday, February 27, 2004 3:40 PM
Yup, I do it. Every book I see here on modelling recommends it.
Posted by Anonymous on Friday, February 27, 2004 3:53 PM
I have been doing it for 15 years ever since I bought my first airbrush and have never had a problem. I can see where the airbrush is covered in paint and has not been maintained how this could cause a problem.
Posted by MikeV on Friday, February 27, 2004 4:19 PM
It won't hurt if you take apart the airbrush every time you use it, but I agree that it is better not to do it if you don't take it apart after each spraying session, which is what I do. I only take it apart after every two or three painting sessions.
    January 2003
Posted by stinger on Friday, February 27, 2004 7:06 PM
I backflush my Iwata HP-CS after, and sometimes during, every paint session. I have often wondered if paint was getting up the needle beyond the cup, but I have had no problems with this technique. I only do it after I have already flushed the cup and have nearly all of the visible paint removed (as far as I can see viewing into the cup.) It helps to get the little cruddies up out of the nozzle area, and they never go any further than back into the cup, where I can fetch them out with a q-tip, or, I'll put a bit more thinner into the cup, shake it, and then dump the bowl into the trash without any further spraying.
Thanks for bringing it up, though, as I'll now take apart my brush just to see if anything is "up the shaft".
stinger
May an Angel be your wingman, and the Sun be always at your six
    December 2003
Posted by buff on Friday, February 27, 2004 7:58 PM
Would it be possible, for the benefit of airbrush noobs like me, to explain exactly what backflushing is. Is it spraying thinner/cleaner through the brush? Thanks in advance
On the bench: 1/32 Spit IXc
Posted by MikeV on Friday, February 27, 2004 8:44 PM
Buff,
Backflushing is when you put your finger or a rag over the tip of the airbrush and hold it there while you push the trigger down and pull back for paint with thinner in the bowl or cup of the airbrush. This causes thinner to backflush through the airbrush and back into the cup helping to flush out any paint that may be stuck in there that didn't make it out when you just sprayed thinner through it after painting. It does help clean it but as was mentioned, it can also cause paint to blow back up the airbrush furthur than the cup and can actually backflush thinner and paint particles up into the needle bearing area where it does not belong. Paint should only be in the area between the color cup and the tip of the needle, if it gets any furthur back up the airbrush there is a potential of both causing paint and thinner to stay back in that area and causing the airbrush to stick and possibly even getting it beyond the needle bearing which could cause it to even get into the airvalve which is not good.
    January 2004
Posted by MusicCity on Friday, February 27, 2004 9:18 PM
Yep, I backflush mine to. But I haven't ever seen paint where it doesn't belong in my Omni or 200. I use gravity feed brushes, and that's really the easiest way to get the paint out of the pickup tube between colors. A bucket of water and a few shots each direction and they are nice and clean. At the end of the day, I completely strip them down and clean them from one end to the other.
Also, when I pull the needle out of my Omni I remove the nozzle and push it out the front so I don't get paint in the back parts. And, when I install it I push it in from the front instead of the back to help prevent damaging the tip.
    January 2003
Posted by plasticmod992 on Sunday, February 29, 2004 11:06 PM
The only airbrush I can backflush without fear of eventual damage is my Paasche-H. The "color adjustment part", specifically the nozzle mixes the paint and air externally and the washer inside the nozzle is solvent proof teflon. For my Iwatas and other airbrushes, I simply turn up the air pressure to around 40 psi according to my cleaning instrusctions (Iwata) and pull back the needle via the cut-away handle. This thouroughly cleans the nozzle. I follow up with a thinner moistened q-tip and swab the color cup, remove the needle and wipe clean.
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by Anonymous on Monday, March 1, 2004 12:11 AM
Just been reading through the little leaflet for my new Wave Advance airbrush.
They actually mention backflushing as part of the cleanup procedure and recommend that the Airbrush be taken apart for a thorough cleaning after it was used 3 times.
BTW, it has a teflon gasket already build-in.
Can't tell you people how happy I am with this brush and consider it a steal at $118 will be picking up the Advance 02 later on this week.
