QUOTE: Originally posted by twistedkrusty
yeah that was the part i was talkin about, so i just pull it out? im afraid to warp it or bend the very end of it so i think i just have to give it some love then it should come out and i will be able to do the full clean down
It should pull right off with little force, if it doesn't try to apply pressure down near it's base where it is thicker to avoid damaging it at the tip. When you clean and put it back together then put it back in the opening it came out of, and hand tighten the head assembly.
Then put the needle carefully into the opening in the handle and push it forward till it comes into firm contact with tip and then tighten the needle chuck screw and you are done.
Don't push it really hard into the tip or you will open it up and possibly split it, a firm contact is all you need. If you are really easy with it and barely touch the tip with the needle when you insert it, then you may find it leaking paint without pulling back on the trigger the next time you use it. You will get the feel for it after only a couple times of doing it.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
