NPS to NPT?
    May 2014
NPS to NPT?
Posted by ShanaSakai on Sunday, May 25, 2014 10:33 PM
Hi guys, I just bought a pressure gauge for my Viair 1 gallon tank, but then when I got it, I realized that it was NPS and not NPT, a quick search on the internet doesn't seem to say much, and the website that shows NPT vs NPS seems to say they are the same except one is parallel and the other is tapered, so does that mean the gauge won't seal tightly with the tank, even with teflon, or it could if anyone knows, the tank will be here on Wednesday so I guess I"ll know sooner or later, but I just want to know so as to decide what adapters to order. Thanks for your time in reading this. Man all this NPT/NPS and BSPP/BSPT is so confusing :/
EDIT: I should have included the item in question, here it is:
http://www.ebay.com/itm/121169922190?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Apologies for so many questions guys, this adapter thing has actually gotten me spending a few hours finding and getting them, will be also posting a pic of my tank design later on to see if it passes.
Here is the design guys, please let me know if there's too much stuff (maybe don't need air ball valve and 2 regulators?) Thank you for your time in responding to my noobish questions. I really appreciate it.
http://imagizer.imageshack.us/v2/1600x1200q90/836/ps2j2.jpg
http://imagizer.imageshack.us/v2/1280x1024q90/836/ps2j2.jpg
    February 2015
Posted by Bick on Monday, May 26, 2014 7:10 AM
Shana,
Seems you have put much thought into your system but, personally, I think it's 'over engineered'! Have a look at some commercial AB compressors with tank and you'll find a much simpler arrangement. You simply need to connect the compressor to the tank, have an outlet from the tank to your regulator then to your airbrush. From the description of your Vlair tank, it has 4 ports - all 1/4" NPT. Get a 1/8" BSP female to 1/4" NPT male and attach to your compressor. Then a 1/4" NPT male extension into one of the ports on the tank. Connect the two with pressure tubing. Screw your gauge into one of the free ports on the tank. From another port on the tank insert another 1/4" NPT extension, connect a 1/4" pressure hose that goes to your regulator then regulator to AB. One thing missing from your schematic is a drain valve. Water is likely to collect in the tank and you need to be able to drain it. I don't think the moisture trap at the compressor is needed (or will do much good), I don't think the ball valve is needed (I empty and drain my tank after each session). I don't remember your regulator but you'll likely need and 1/4" NPT male to 1/8" BSP male or an 1/4"NPT male extension from the regulator and a another 1/4" NPT female to 1/8" BSP male.
    May 2009
Posted by Pawel on Monday, May 26, 2014 8:36 AM
Awright, I use a system that's similar to the one on the drawing. It looks like this:
I also have a moisture trap at the supply port of the tank, made out of a gas bottle. I had no way to drain the tank, so at least I wanted to keep it as dry as it gets. This way the air has the opportunity to cool down in the coiled line before it hits the moisture trap. But on the delivery port of the tank I only have a safety valve and a regulator, that also works as a shutoff valve if necessary (if you turn it down to 0 psi). The quick disconnect also is airtight if you disconnect it. So you don't need a valve, for sure. You also don't need a separate fitting for a gauge - you got one on the supply line, on the moisture trap, showing you what's inside the tank, and another one on the regulator, showing you what's coming out.
Hope it helps, have a nice day
Paweł
www.vietnam.net.pl
    October 2011
Posted by modeler_zack on Monday, May 26, 2014 9:35 AM
Shana, check out if you have a Parker store near you. Parker is a storefront that supplies pneumatic and hydraulic hoses and fittings. They most likely will be located in an industrial park but they do sell to anyone. If you don't have one in your area, look for grainger.
    February 2015
Posted by Bick on Monday, May 26, 2014 10:35 AM
Shana, after my post above it occurred to me that you really only need two adapters to do what your want. And, if there's a Harbor Freight near you, you can get all you need there. The Harbor Freight airbrush hoses come with 1/8" BSP hose ends plus a 1/8" BSP male to 1/4" NPS female adapter (see my pic below). Get two of them (about $6 each when I bought the one shown). Screw one end of the hose into your Sparmax compressor (it will fit) and, using the adapter attach the other end to a 1/4" male/male extension which you screw into your tank. Attach another 1/4" extension into your regulator and then screw regulator into another port on your tank. If needed, add another extension to the regulator and attach the second hose - adaptor first - to you regulator. The other end of the hose will fit you airbrush. Any other connections you wish to make are all 1/4" NPT and easily available (at Harbor Freight or local hardware store) i.e. tank pressure gauge, drain, pressure relief valve etc.
BTW Pawels set up is very nice - and probably very quiet (refrigerator compressor?) but more complex because of the few (one) tank ports. Anway, HTH.
EDIT If no Harbor Freight nearby you can get the adapters here:
http://www.chicagoairbrushsupply.com/iwaitobaho.html
    May 2014
Posted by ShanaSakai on Monday, May 26, 2014 12:51 PM
Hi and Wow I read all of that, thank you very much guys! I knew I forgot to mention something though, is that I have everything on there except for the moisture trap, ball valve (but I don't need it so), and, as Bick said, 2 adapters. I realize that the 2nd one isn't really needed, but I'm always a "rather be safe than sorry" type of guy, and especially since I read the other thread about having a 2nd moisture trap to be safe. I probably will follow Pawel's setup almost, and I see I don't need the NPS pressure gauge anymore, which is good, but just to make sure, the 2nd moisture trap I'm getting is this:
www.ebay.ca/.../271328574117
it includes 2 1/4 male BSP to 1/8 Male BSP
so that alone will be enough to stop the air coming OUT of the tank when not in use? In the new setup below? (A little too bad cause now that NPS gauge will be useless and on the side, oh well only $12 for it xD)
http://imageshack.com/a/img835/3836/2pc2q.jpg
http://imageshack.com/a/img839/8691/09yy.jpg
Once again thanks for spending time on helping me.
EDIT2: Looked and the closes Parker is 90 km away :( (I live in Canada), and there is a grainger nearby, so I'll check that out, but if they don't have the 2 adapters, I'll just order from a guy on ebay in UK who has everything :D
EDIT3: I don't need a check valve do I?
