Does the Iwata Eclipse have solvent resistant seals ?
Posted by Anonymous on Saturday, February 28, 2004 10:41 PM
Does anybody know if the Iwata Eclipse have solvent resistant seals ?
Thanks
Posted by MikeV on Saturday, February 28, 2004 11:04 PM
I am not sure about the Eclipse BCS but the BS and CS models do not have solvent resistant needle bearings. They can be upgraded to Teflon bearings for about $15 more from Coast Airbrush.
    January 2003
Posted by plasticmod992 on Sunday, February 29, 2004 2:50 PM
Actually Mike they do. I called Coast and they told me that they were solvent resistant but not solvent proof. I've since sent my HP-CS to them for the teflon Upgrade which is "solvent proof" guaranteed for the life of the airbrush.
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by MikeV on Sunday, February 29, 2004 3:11 PM
Thanks for that added info Greg.
I knew they could handle most solvents alright but I was unaware whether they were "solvent resistant" or "solvent proof." Big Smile [:D]
Posted by wibhi2 on Sunday, February 29, 2004 3:47 PM
where are the seals? I only noticed the rubber "o" ring. Are there others near the tip. I have an Iwata Ecilpse BCS
3d modelling is an option a true mental excercise in frusrtation
Posted by MikeV on Sunday, February 29, 2004 4:46 PM
The one we are talking about is the needle bearing which is between the siphon tube and the trigger in the airbrush body. They have to be replaced with a special tool that removes and installs them.
Posted by wibhi2 on Sunday, February 29, 2004 7:34 PM
cool, thanks. As a first time Iwata owner, how would I know it's time for replacement?
Posted by MikeV on Sunday, February 29, 2004 11:22 PM
I forgot to mention that you don't have to worry because I don't believe the HP-BCS siphon-feed Eclipse you have has a needle bearing, unless I am mistaken.
I know that the Omni 3000 does not have one, although the Omni 4000, 5000 and 6000 do.
    January 2003
Posted by plasticmod992 on Tuesday, March 2, 2004 3:17 PM
wibhi2,
I have a HP-BCS as well and MikeV is correct, the BCS doesn't have nor require the needle bearing.
    March 2012
Posted by Dr.Juice on Wednesday, March 28, 2012 12:14 PM
Hi, i know this is a verry old conversation, but i just fell on it looking for infos on my hp-bcs. I am wondering if it is ok for me to sink it in thinner to clean it up .. i use urethanes and basecoats in it, i know its ok for me to juste let the thinner flow in it for a light clean up, but ... you know .. can i sink it in thinner ? ..
thanks alot :)
    December 2003
Posted by hkshooter on Sunday, April 1, 2012 2:25 PM
No, not without removing the air valve. Take that out and be sure to remove the orings and have at it.
    March 2012
Posted by Dr.Juice on Tuesday, April 3, 2012 4:00 PM
Hi, i forgot to mention this airbrush is a HP-BCS, doesn't have a removable air valve .. this is actually why i am not sure if i can soak it in thinner .. because i don'T know if there is a oring inside the valve that could be dammaged by the solvent .. :P
