Tamiya liquid surface primer
    December 2012
Posted by Thwaite on Thursday, June 12, 2014 3:01 PM
Hey guys. Has anyone had any luck using the tamiya liquid surface primer. The 40 ml bottle not the rattle can.  If so what sort of ratio would you thin it for airbrushing. Having just bought a bottle any suggestions would be much appreciated, thanks in advance.
On the bench: 1/32 trumpeter Douglass Dauntless ,1/48 tamiya Lancaster
    December 2011
Posted by Chrisk-k on Thursday, June 12, 2014 6:11 PM
In my experience, it's the most foolproof primer.  I thin it with Tamiya lacquer thinner to a 1:1 ratio & shoot it @ 20 psi. Because it adheres to plastic extremely well, you don't have to worry too much about surface prep.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    July 2004
Posted by stikpusher on Thursday, June 12, 2014 6:40 PM
I have used it as well. I thin it with generic hardware store lacquer thinner, also a a 1:1 ratio, and it airbrushes just fine. I cant tell you the PSI that I use, becuase my compressor has no PSI guage, only a valve to increase or decrease the pressure. But it works really well I must say.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    December 2012
Posted by Thwaite on Friday, June 13, 2014 11:07 AM
Thanks for the replies guys. I'll give it a go this weekend
