Messed up my airbrush, will it ever spray again?
    March 2011
Posted by modeler#1 on Saturday, June 21, 2014 9:01 PM
So i got the end of a q-tip tuck in the front of my airbrush. I used a dremel among other tools to remove it. it looks quite damaged to me. I like German camouflage schemes would I be able to produce them with this amount of damage?
P.S sorry for the blurriness, you get the idea
On the Bench: Nothing atm
    April 2004
Posted by Jon_a_its on Saturday, June 21, 2014 11:49 PM
[:S ] looks like toast mate, not good.
I know Iwata & Badger have 'intensive-care' units in their maintenance depts., but  this may be beyond that
You need to be able to get a good seal between the body and the nozzle, which is why it is smooth. (part names from Iwata, diagram, below, btw)
I don't think reaming it out will work as you will then change the spacing/gap between the nozzle cap/head cap assembly.
You also need to get it centred to the needle & nozzle cap/head cap assy. Diagram here
You might be able to use beeswax thinly smeared on the tapered rear end of the nozzle, (& on the thread on the body where the head cap fit) as recommended by someone in my hobby club.
I use the smallest of this set of micro-brushes to deep clean inside the body, & plastic handled kids paint brushes to clean the paint bowl.
In extremis, reverse the needle, & feed it through the body from the rear & gently push.
Q-tips are reserved for the outside, & ear-holes only! Huh?
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    December 2011
Posted by Chrisk-k on Sunday, June 22, 2014 4:04 AM
It looks pretty much done.  Use interdental brushes to clean inside your airbrush.  They cannot damage or scratch airbrushes but they are strong enough to scrap off any paint residue.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    October 2008
Posted by P mitch on Sunday, June 22, 2014 5:04 AM
As everyone has said it's done. You may be able to get the body replaced which could save some money. Best advise from me would be power tools and airbrushes will never be friends.
Sorry to say if you'd come on here and asked someone may have been able to help.
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    October 2008
Posted by Don Wheeler on Sunday, June 22, 2014 10:49 AM
It looks like a Badger 155.  You could get a new body from this dealer for about $32 if you use their discount code.  If it is a Badger, I would contact them and see what they can do for you.  E-mail and attach a photo.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
Posted by Don Stauffer on Sunday, June 22, 2014 11:32 AM
Indeed even the bigger parts like the main body are always considerably cheaper than replacing the whole airbrush, with almost any airbrush.
    May 2013
Posted by Greg on Sunday, June 22, 2014 11:45 AM
I just want to second Chris' comment about interdental brushes. I didn't know that is what they are called, but I use them too. Not the ones with wound steel centers though! Don't know why those are even sold, I'm no dentist but those can't be good for our teeth, let alone our airbrushes.
Sorry about the damage to your brush.
    December 2011
Posted by Chrisk-k on Sunday, June 22, 2014 12:28 PM
I have a set of micro cleaning brushes, which I no longer use. Their steel centers can scratch airbrushes.
I have interdental brushes in various sizes. The smallest one can easily clean inside a 0.2mm nozzle.
    May 2013
Posted by Greg on Sunday, June 22, 2014 1:26 PM
Can you expand on the interdental brushes in various sizes, Chris? Source, etc? If I get ambitious, I might post a pic of the ones I use (from local grocery) if anyone is interested. Great for cleaning the inside of the nozzle tips, et al)
Odd you mention the micro cleaning brushes. I have the same set as john_a_its and I use the smallest one to clean the through hole (where the needle slides through). I'm getting a lot of paint backing up into the needle, and am worried I am expanding the through hole with the micro brush (the steel center, as you mentioned, Chris). Can't think of another way to clean that hole.
    April 2004
Posted by Jon_a_its on Sunday, June 22, 2014 2:54 PM
I use those inter-dental brushes as well, the smaller ones are nylon, but they aren't long enough to get to where the middle needle bearing is, d'oh
Don't feed the CM!
    December 2011
Posted by Chrisk-k on Sunday, June 22, 2014 4:31 PM
@Greg
I use Piksters.  They come in 10 different gauges, I think.  CVS has them.  So do online drug stores.
@Jon
Take out the brush head with a plier and superglue it to a syringe needle (See Don's AB page for more information).  A syringe needle of a gauge higher than 20 is thinner than the thinnest airbrush needle, so it will reach anywhere inside an airbrush without damaging it!  I bough 100 gauge 22 syringe needles for $3 on eBay.
    May 2013
Posted by Greg on Sunday, June 22, 2014 6:52 PM
Thanks for the info and the tips, Chris.
