cleaning techniques for Iwata Neo CN
    July 2014
Posted by sachman on Wednesday, July 2, 2014 8:28 PM
This is going to seem like a silly question for the experts here, but I figured I'd ask anyways...and forgive me, I am new to airbrushing (i have been using brushes until now). I have an Iwata Neo CN (gravity feed). I will use mostly (or at least firstly) acrylics. What is the best way to clean the AB after each use? Is there some routine cleaning that should take place after X number of uses? SOme details on cleaning the brush and the intake from the cup is what i am after. If there is a detailed step-by-step web site, please let me know.
If I switch to enamels or oils, same question about cleaning.
And for the acrylics (Tamiya), I was told to use about 10% thinner (from Tamiya) with the paint. Sound right? Cheers.
    March 2013
Posted by patrick206 on Wednesday, July 2, 2014 11:51 PM
Hi, Mike -  For a thorough and well presented introduction to airbrushing in all aspects, I recommend a look at "Don's airbrush" site. Just Google Don's airbrush tips and you'll find whatever you need in the way of using, cleaning and assembling airbrushes. He even includes your exact Iwata in the text and photos. Any problems with locating his site, just check back in.
Good luck with it and happy spraying.
    August 2005
Posted by Phil_H on Thursday, July 3, 2014 12:30 AM
sachman
There's no hard and fast rule about how much thinner to use. It depends on your airbrush setup, your individual preference and what you are trying to achieve.
I tend to thin more than most with Tamiya acrylics, often in the order of 75% thinner to 25% paint. It works for me, but that's what I'm used to. It may be different for others.
cml
    March 2007
Posted by cml on Thursday, July 3, 2014 6:23 PM
Sachman - here's the link to Don's website: sites.google.com/.../donsairbrushtips
It is quite invaluable to anyone wanting to learn the basics of airbrushing.
I see he also has an online book now.
I'll echo Phil - thinning is a personal preference. I use mainly acrylics. When I started out, I thinned around 2:1 paint to thinner, as this was what most people seemed to suggest. I also used to use around 15-20 PSI.
However, after my own experimentation, I now prefer a 50/50 mix at around 30 PSI. It means you take longer to build up coverage and may be more prone to runs etc when first learning (due to thin paint and high pressure), but it's what I prefer. Also, given it's acrylic, the higher pressure evaporates the alcohol base very quickly, so it touch tries almost instantly (though should always be properly cured before masking etc).
Chris
    December 2011
Posted by Chrisk-k on Thursday, July 3, 2014 8:30 PM
There's a ton of resources on how to clean ABs on the Net.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
