How to paint wheel wells
    July 2014
Posted by sachman on Sunday, July 6, 2014 11:13 AM
I was thinking of airbrushing the bottom of my model (F-18) and then handbrushing the wheel wells white. I have seen videos where it is recommended to paint the wheel wells first, mask them and then airbrush the body. My question is, how do people here handle this? Do you always handbrush the wheel wells; does it depend on the model? Never do it this way? The shape seems a bit awkward to mask so I thought this appraoch might be easier. Thanks.
Posted by Tojo72 on Sunday, July 6, 2014 11:37 AM
I paint my wheel wells first,then I stuff them with wet facial tissue to mask them,that's the only way I have done them.
    October 2007
Posted by Milairjunkie on Sunday, July 6, 2014 1:27 PM
I airbrush the wheel wells first (covering any gear or door mounting holes / tabs to save scraping later), then cut a lump of sponge to fill & mask them with before putting down the main colour coat.
Posted by Bish on Sunday, July 6, 2014 1:30 PM
I am the same as the other guys, using tissue to mask, held in but small strips of masking tape if needed.
I normally airbrush them and defiantly would for white one. hand brushing white is a real pain.
cml
    March 2007
Posted by cml on Sunday, July 6, 2014 4:03 PM
I do the same as Tojo72, but will add that I line the well tape first along the vertical sides of the well before stuffing with tissue.
Other times, if its a really tedious shape, I'll use Humbrol Maskol, applied with a toothpick.
Chris
    November 2003
Posted by mississippivol on Sunday, July 6, 2014 5:56 PM
Paint first, and I've become a fan of using silly putty to mask them off when painting the body.
    July 2010
Posted by roony on Monday, July 7, 2014 10:23 AM
I would like to add,  wheel well first,  then mask.  Then I roll the masking tape, sticky side out, and put the gear covers in place.  This helps the masking and you get the doors matching.
    December 2011
Posted by Chrisk-k on Monday, July 7, 2014 12:55 PM
Paint the well first and mask with silly putty or blue tac.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    March 2005
Posted by TarnShip on Monday, July 7, 2014 2:42 PM
I do a lot of kits in multiples, so I have cut out foam masks for each kit to fit into the wheel wells.
You just spray the wheel wells, pop in the foam masks with tweezers, they expand out to the well edges, and you spray the underside color,,,,,,,picking the masks out and saving them for next time.
You can get the foam in small sheets at Wal-Mart and Hobby Lobby, they are 5 by 7 inches or so, and come in a stack of 50 or more different colored sheets of "Sticky backed foam". I used to peel off the backing and stick them in place,,,,,,,but, I have found they work just as well leaving the backing on.
Rex
almost gone
