Badger head washer lifespan?
cml
    March 2007
Posted by cml on Monday, July 7, 2014 9:21 AM
Howdy all,
For the past few weeks I've had issues my Badger 100LG back flushing during normal painting (ie, without blocking the tip).
In the past, a full breakdown clean fixed the issue, but not tonight. After almost 2 hours of breaking it down, testing, head scratching etc, I thought I'd open up a spare head assembly and replace parts to see if that fixed the issue.
it was fixed with the first part replaced - the Teflon head washer. I then kept switching back to the old one to make sure that was the problem and not some fluke - it was the problem.
i did a visual inspection and can't see that their is any issue with the old one, both have same diameter (so it hasn't expanded) same width (so not compressed).
ultimately, how long should these head washers last? It's the only part Ives had to replace in over 5 years since i first purchased it, so I can't complain, more curious.
i think I'll stock up a few more, would love this brush to last at least another 20 years if it can.
Chris
    October 2008
Posted by Don Wheeler on Monday, July 7, 2014 12:43 PM
The head washer does compress a little over time.  It doesn't take much to cause a leak.  You might have to compare the old and new parts with a micrometer or calipers to see the difference.  On my airbrushes that have this, I leave the head a little loose between uses to try to make them last a little longer.  Also, I've found that a leaky washer will sometimes still work if I put a little Chapstick on the threads.
I'd say five years is an excellent life span for this part.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    May 2011
Posted by Real G on Monday, July 7, 2014 4:56 PM
You may have a hairline crack on your original washer.  I have only replaced the washer when the previous one goes flying off into the backyard where I paint, or otherwise gets lost during the cleaning process.  I have never had one wear out on me, so I think it is likely that yours is damaged.
“Ya ya ya, unicorn papoi!”
cml
    March 2007
Posted by cml on Monday, July 7, 2014 6:17 PM
@Don - thanks for the input Don. Good to know about the washer lifespan too. Given they retail for less than $2.00, 5 years is great value.
I'll have to add a chapstick to my inventory of bizarre modelling supplies too (along with the facial sponges, nail files, cuticle probes, nail polish remover etc Wink)
@Real G - that's a real possibility too. Admittedly the thing is so small it's hard to see much with the naked eye.
Just glad i was able to fix it relatively quickly.
Chris
