Silvering
    May 2014
Silvering
Posted by Sackgasse on Monday, July 14, 2014 6:20 PM
Hi,
Fairly new here so please be patient...My understanding is that:
I need X-22 Clear to ensure I do not get silvering under decals
I need X-21 Flat base to get it back, nice and tidy...
So what is XF-86 Flat Base?
How is this best used?
Happy Modelling!
Zack
Happy Modeling! Cool
    December 2011
Posted by Chrisk-k on Monday, July 14, 2014 6:37 PM
The Tamiya Flat Base is an additive to make a gloss paint dull. You NEVER ever directly apply it to a model.
A sequence that I (and many modelers) use is:
1. Gloss coat (e.g., X-22 or Future)
2. Decals
3. Gloss coat to seal them
4. Washes
5. Flat coat.
I apply Future, place a decal on **still wet** Future and seal it with Future. With this method, it's impossible to get silvering.
You can mix X22 and X21 (3:1 or 2:1 ratio) to make your own flat varnish, but it's just easier to buy an acrylic flat varnish made by W&N or Vallejo.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    August 2005
Posted by Phil_H on Monday, July 14, 2014 7:33 PM
X-21 Flat Base is an additive which is mixed with gloss colours to make them flat (or anywhere between). It is not a clear flat coat and should not be used as such.
XF-86 is a ready to use flat coat. I haven't used it, so I don't know how well it works.
Posted by Don Stauffer on Tuesday, July 15, 2014 9:24 AM
Any gloss clear coat will work to prevent silvering. It does not need to be a specific brand or product.  Then, if you want a flat final finish, there are many flat clear overcoats available.
    May 2014
Posted by Sackgasse on Tuesday, July 15, 2014 1:21 PM
Thank you for your confirmation points.
I have just messed up with a direct application of  X-22 Clear and a subsequent coat of XF-86.
The streaks (pencil applied) of the X-22 are visible through the XF-86.
Time to use tigermans dot filter :)
Happy Modelling!
Zack
