I've given up.
I know what the jets I used to be around looked like, so I don't gain anything by trying to tell people that the panel lines don't stand out as we see in the current trend. I used to try and explain what a pressure washer was for in a USN/USMC squadron, where people just weren't allowed to walk, etc.
I will build without them highlighted on my own models.
Besides, I was just amused at this line in a reference book
"Please note that the drawings cannot themselves be used as accurate guides for the kit modifications, since they are in many cases composite drawings showing many of the options and changes which could be applied to the model."
Which means that I bought two books because reviews described all the fantastic drawings in them,,,,,,,,and the drawings are really just "visual parts lists",,,which I could have (and did ) have done in text format.
Besides, three kits in the same scale from different manufacturers have different panel lines on them,,,,,,,and it would take a book of just panel line photos for EACH aircraft (including all the sub-types**) just to know which ones to rescribe.
I'll stick with just adding some shadow down in the joints between movable and fixed surfaces.
Rex
(**Early F-4B, Later F-4B and F-4J have different doors and locations on them,,,,,,,these are panel lines that actually open,,,,,,,,most kits ignore this or mold all their versions with the same panels,,,,,,,,USN or USAF,,,,,,highlighting these would just call attention to the fact that the panels weren't right on the model)
