Surface primer
    September 2012
Surface primer
Posted by Squatch88 on Wednesday, August 20, 2014 7:50 PM
I have seen a lot of people using Mr. Surfacer on models. I have a project that I've done a lot of filling and sanding and am curious about the stuff. 1) What is the it? 2) Any special prep to it before the colors(I use acrylics) 3) Any tips/products you like for priming would greatly help my build go to the next level!
Posted by Don Stauffer on Thursday, August 21, 2014 9:14 AM
Personally I like Krylon spray can primer, but I know a number of friends who use Mr. Surfacer wtth good results.
    April 2009
Posted by Cadet Chuck on Thursday, August 21, 2014 11:03 AM
Never tried Krylon, but Mr. Surfacer and Tamiya Fine Scale Primer work just fine for me.
    November 2008
Posted by mrmike on Thursday, August 21, 2014 12:36 PM
Tamiya's Fine Surface Primer is my choice in rattlecan, but my go-to is Alclad Primer and Microfiller using  an airbrush, medium tip at 20 psi plus or minus. I prefer the white since it contrasts with grey plastic and makes blemishes easier to see and sand, but I've seen examples of using black as a base for preshading shadow detail. I'm going to try that on my next armor build.
I buy sanding supplies at a paint store that sells auto body products. In addition to very fine grades of wet & dry sandpaper they carry  4-1/2" x 5-1/2" 3M foam backed pads in finishing grades that are perfect for "polishing" the surface before and after priming. They are easily cut to size, can be used wet or dry, and last a long time. Compared to hobby prices, the paint store stuff is a real bargain.
    January 2014
Posted by jelliott523 on Sunday, August 24, 2014 7:54 AM
I too use Krylon as my base primer, something I picked up from our friend Don.  However, I also have some Mr. Surfacer 1000 that I picked up at my LHS.  I have used it on seams where there was just a slight depression even after using some putty.  I used this as a couple of light coats applied with a fine brush along where the seam was showing.  It filled in nicely and was able to sand out the edges making a smooth surface.  I then used the Krylon rattlecan to coat the rest of the model.
I should have taken a picture of the work to show the before and after.  I'll keep that in mind if I have to do that again.
Posted by Tojo72 on Wednesday, August 27, 2014 4:11 PM
I like to use the Mr Surfacer 1200 in the rattlecan,it's simply primer that you spray on before painting,it fills in small defects,and helps you see the bigger ones that need correcting.I also use the Tamiya Fine which is the same stuff in the rattlecan if I can't get Mr Surfacer.
    June 2013
Posted by RobGroot4 on Wednesday, August 27, 2014 10:31 PM
This may seem like a dumb question, but what do you thin Mr. Surfacer with?  The instructions are all in Japanese so I can't read them!  Thanks!
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    March 2014
Posted by JaySantos on Thursday, August 28, 2014 9:27 AM
I use Mr Color Leveling Thinner to thin mr surfacer. This combination works very well for me.
Jorge
