Silver Dope
    January 2014
Silver Dope
Posted by jelliott523 on Friday, September 26, 2014 5:37 PM
I have been looking through several posts before I decided to ask this question, but since I haven't been able to find anything specific on the topic I'm going to go ahead and ask...
I am going to be working on a Monogram 1/48 F-102 in the rare Idaho Air National Guard silver dope scheme.  I've seen some pictures that I am going to use as a reference; however, my question is this, what is the best way to match the color "silver dope".  I have kicked around trying to use Alclad Airframe Aluminum and then doing a light coat of dullcote over the top after the decals have been applied.  I've also looked at using the Tamiya AS-12, coating with PFM, applying decalsl, then dullcote.
Any suggestions would be appreciated.  If I go the Alclad route, it will be my first attempt at using this product.Confused
Posted by Texgunner on Friday, September 26, 2014 8:14 PM
You might try Humbrol MetalCote in polished aluminum.  I know it says "polished" but its not really that shiny.  Might be just the shade you want.  I did a Monogram P-51D in that and it looks quite a bit like the silver painted Mustangs I've seen.   That paint is also available in unpolished aluminum.  I've use both quite a bit.
Gary
"All you mugs need to get busy building, and post pics!"
Posted by Don Stauffer on Saturday, September 27, 2014 12:00 PM
Aluminum doped surfaces can have a very high gloss, depending on who painted it.  On many civil aircraft it is quite a high quality surface.  On military planes it may be slightly less so, but still pretty shiny.  I use Testors gloss silver.  I really recommend paint, rather than Alclad, because it is, and looks like, a paint.
One reason it is used a lot is because aluminum paint stops UV damage to fabric, so it was used as an undercoat before spraying on the final color coat.  But, hey, since the aluminum is really all you need, why not leave it just aluminum color?  I know several folks refinishing aircraft that went that route for that reason.
    January 2014
Posted by jelliott523 on Saturday, September 27, 2014 12:26 PM
Don Stauffer
Don, so would you suggest that I find aluminum colored paint and go that route?  Maybe hit it with some semi-gloss clear to give it that shiny, but not too shiny coat?
Posted by Don Stauffer on Sunday, September 28, 2014 11:15 AM
I think just a gloss aluminum or silver paint- don't worry about dulling it, but do not gloss clearcoat it either.
BTW, Navy planes of the thirties were often painted aluminum or silver.  They didn't like using bare aluminum in a seawater environment.  Those were pretty glossy too.
