Flat Finish: Dullcote vs MicroMark Flat vs Winsor &Newton Acrylic Matt Varnish
    September 2014
Posted by U2 Milo on Thursday, October 9, 2014 10:44 PM
After reading Chrisk-k's enthusiastic endorsement of the W&N acrylic matt varnish I had to check it out.
Coming from the model rr world, we like dead flat finishes.  Dullcote is a staple.  But with my new indoor paint station, I would like to get away from the high VOC stuff.
So I ran a simple test using Dullcote, the W&N, and some MicroMark Flat (made by  Vallejo).
The Dullcote was thinned with lacquer thinner.  The MicroMark with Vallejo Thinner.  The Winsor & Newton with distilled water with a couple drops of flow aid.
Perhaps not so visible in the pic, but the Dullcote and MicroMark Flat were really close in appearance:  Dead flat.  The W&N was more of a dull satin finish.
The Dullcote and MicroMark dried much faster (could be handled sooner) than the W&N.
The MicroMark Flat and the W&N Matt Varnish had smoother finishes than the Dullcote.
I was impressed with the MicroMark flat.
Comments welcome.
Mitch
Tags: flat finish
    December 2011
Posted by Chrisk-k on Friday, October 10, 2014 11:44 AM
I spray the Vallejo and W&N matt varnishes straight out of the bottle.  Unless I want to heavily weather a model, I use the W&N.  I've watched a ton of videos and examined photos of WWII & Vietnam AFV's, and most of them don't look dead flat.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    September 2014
Posted by U2 Milo on Friday, October 10, 2014 12:15 PM
Glad you commented, Chrisk-k.
No disagreement.  We use the dead flat for old freight cars and such.  I'm new to the airplane world and can see the value in a satin finish.
Two great low-VOC products to add to the arsenal.
    March 2010
Posted by Nathan T on Saturday, October 11, 2014 12:59 PM
I thin the Windsor and Newton varnish with Tamiya white cap thinner and it works real well. I mix it Matt and Satin together so its not quite dead flat. Best flat clears I've ever used.
    September 2014
Posted by U2 Milo on Saturday, October 11, 2014 2:30 PM
I thought the W&N Matt was kind of satin-ey, compared to the other two.  But I'll give it a shot with the Tamiya thinner.  I'm curious if that helps it dry any faster, as well.
Thanks for the tip.
    March 2010
Posted by Nathan T on Saturday, October 11, 2014 6:59 PM
Seems to dry to the touch within 10 min or less.
