Ridges of paint along masks
Posted by 7474 on Thursday, October 23, 2014 9:44 PM
I have a 1/48 Falcon 10 kit that I'm working on, have to strip the paint and restart. I was doing black towards the front, red on the rear and a white band in between. I painted the white first, then the red, but when I pulled the masking tape up, there was a ridge that I tried to sand away. The red then dirtied up the white paint. I was using rattle cans. Any way to paint and not get a ridge?
    December 2006
Posted by Fly-n-hi on Friday, October 24, 2014 12:07 AM
Was the red gloss?  You can use flat red and then spray a gloss coat over that.  Gloss paints have to be sprayed on a bit thicker which contributes to the ridges.  But with rattle cans it may be hard to eliminate the ridges no matter what.
    October 2007
Posted by Milairjunkie on Friday, October 24, 2014 8:12 AM
Spraying towards the masking will cause a build up of paint - spraying at 90° or more to the masking edge will prevent paint accumulating against the edge.
Posted by 7474 on Saturday, October 25, 2014 11:13 AM
Yeah the red is gloss. I'll try with painting with a flat at a 90 and slowly build up the paint. Thanks guys.
    August 2013
Posted by Straycat1911 on Saturday, December 27, 2014 7:18 AM
I read in FSM a general tip that to avoid ridges, remove the masking ASAP after spraying; don't give the paint time to set and build a ridge. "Shrug". Not sure if it works or not.
    July 2008
Posted by jeffpez on Saturday, December 27, 2014 8:01 AM
I've found that using an air brush rather than spray cans helps the problem because the cans blast far too much paint.
Posted by Don Stauffer on Saturday, December 27, 2014 9:09 AM
If the finish will be matt, one can sand those ridges with very fine paper- 1500 or finer, and the paint will not show the sanding.
    September 2014
Posted by Cloud Hopper on Saturday, December 27, 2014 9:43 PM
I would suggest if you don't already have one, invest in a good airbrush.  My first AB was a Badger 200 which I still have and is my go-to brush for a lot of my painting jobs.  Airbrushes have way more control than the rattle-cans.
    June 2014
Posted by USAFASME7 on Monday, March 2, 2015 2:55 PM
De-masking while the paint is still relatively wet DOES work! It's how I was taught to paint real aircraft 26 years ago. The demarcation line lays down with no ridge.
--Rob
Glue Sniffer since 1977
