Best way to camoflage an airplane?
Posted by echolmberg on Wednesday, November 12, 2014 7:09 PM
Hi guys!  I'm about to paint my A-37 Dragonfly in a camo pattern.  What's the best way to apply the colors?  I know you're supposed to start with the lightest colors and then progress to the darker ones.  I was wondering if you have to (or should) paint the ENTIRE plane the lightest color first or could you only paint the patches that need to be painted without having to paint the entire airframe.  I hope that's all making sense.
Thanks!
Eric
    March 2005
Posted by TarnShip on Wednesday, November 12, 2014 8:14 PM
That sort of depends on two things.
One is if your paint sticks really well to the plastic when masked, so you don't need any primer coat.
The other is how thick you put your paint layers on. If you are painting really thin, then each coat of paint you put on with have "colored preshading" at the lines where the colors overlap. You can do this on purpose, to get a good "blending in" effect, if you paint the first and each succeeding color exactly where you want the separation line to be (sort of how it is done in real life)
if you need a primer, or if you think you will have color bleed through,,,,,,,then you should put the light color over the whole airframe, then the next color, then the last.
It really depends on your own painting style.
Rex (former Cheesehead from Wis Dells)
almost gone
    July 2004
Posted by stikpusher on Wednesday, November 12, 2014 8:43 PM
On a SEA camo scheme like on your tweet I would suggest doing the lower light gray first, then the upper side scheme, lightest to darkest, then finally go back and touch up the light gray to get rid of any upper color overspray and even out the upper/lower demarcation line. That's how I do my SEA color schemes.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Don Stauffer on Thursday, November 13, 2014 9:36 AM
Personally, I prime even for flats.  For camou, I do the entire model the light color- saves masking.
Posted by Texgunner on Thursday, November 13, 2014 10:07 AM
I'd say throwing camouflage netting over it, or a bunch of tree branches?
Sorry Eric, I just couldn't resist...just being goofy on a Thursday!Big Smile
Gary
"All you mugs need to get busy building, and post pics!"
Posted by echolmberg on Thursday, November 13, 2014 2:38 PM
Gary, you're not too far off from the truth!  LOL!  I once built Revell's 1/72 P-38 and I wasn't overly happy with the job I did on it.  It wasn't bad but I knew I could have done better.  I ended up building a diorama with it and I threw a big "tarp" over the center fuselage using the wet Kleenex method in order to hide my gaffs.  Stick out tongue
And thank you everyone for the great advice!  I've already primed it with Tamiya's grey primer.  I love that stuff!
Can you tell that I just don't do a whole lot of jets?  I mostly build WW2 U.S. aircraft so my choices are pretty simple in terms of paint schemes.  Oh that reminds me.  I should pick up some Silly Putty on my way home tonight.
Stik, this Tweet will be my 2nd plane for the Monogram Mafia group build.  It's been sitting primed and ready for the past month now but I've just had so many other family-related things to do that it's taken me this long to get around to it again.  I'm so excited!  It's going to be my first GB badge ever!
Eric
    August 2013
Posted by Straycat1911 on Saturday, December 27, 2014 7:04 AM
Best way to camouflage an airplane?
Sorry Eric, I just couldn't resist...just being goofy on a Thursday!Sorry Eric, I just couldn't resist...just being goofy on a Thursday!
Gary
Lmao! Gary, you beat me to it!
